I need new shocks for my modified fastback for street use. Konis would be nice, but looking for something a little more affordable, but without a bone jarring harsh ride. I'm considering Bilsteins. Any ideas?
I put KYB Gas-Adjust units on both Mustangs years back and am well satisfied with their performance.
Troy, I have a pair of front GR-2 KYB shocks that have less than 2,000 miles on them. They were on a 68 CS when I purchased the car, and were removed and replaced with the Gabrial gas shocks. Nothing wrong with the ride, I just wanted the looks of the Gabrial. The ride was just fine with them, maybe a little more harsh than the Classic line of gas shocks from Gabrial but certainly did not rattle my old bones. Send me a PM and ask any questions about the ride. I drove them home from Northeast PA to Illinois and they felt good. PM me if you have any speficic questions.
I had KYB shocks and didn't like them - too harsh. Looking for something a bit better/different.
My kyb's are pretty harsh, too, I would like something softer, I have plenty of swaybar and springs for cornering, softer shocks would improve my drivability.![]()
Murf,
What Gabriel's did you use and do you like the ride on them?
Jack
I used the Gabrials as listed in the "Classic Car Line" at Autozone. They are an "almost" dead ringer for the original Autolite shocks if one used the thicker washers available from AMK, and the ride is just great. Smooth as the originals in my opinion. I am very happy with them, this is the third Mustang I have put them on and all three give a plush ride with the added advantage of a gas shock.
Yes they are very pricey but I do love the Koni shocks on my car. I put them on 12 years ago and never regretted spending the extra money.
Jack
I agree with Murf on the Gabriels if you want a concours replacement. If you take the time to prepare them by filling in the "57" stamped in the top of the front shocks and then repaint them black they are as close to originals as you can get.
Quote from KmanYes they are very pricey but I do love the Koni shocks on my car. I put them on 12 years ago and never regretted spending the extra money.
Jack
and the adjustability is a great feature. the softest setting is very easy on an aging driver. And the factory will rebuild them when needed.
I have had the same Konis on my Kar for over 25 years and I am very satisfied with them. They are the only shocks that I have had that held up for such a long period of time and are still doing their job as they did when new. The extra money was well spent in my view.
I've had Edelbrocks on my 66 for several years now. They replaced Konis and I find their ride a good compromise between stock and ultra-stiff. Several others in our local club converted after riding in mine and all have the same response. Haven't talked to anyone yet who didn't like them. They stiffen up in hard cornering, but relax a bit when cruising, making railroad tracks much easier to tolerate. It's due tp their patented internal IAS (inertia-activated)valve - or so they want you to believe.
DS
I am running original (never repaired) Konis on my
65 Shelby. They are all dated 4 65. Got the front ones
from a friend and they have the thick upper ring and the
rear ones I found in a box in my garage. Probably were on my car
when I bought it in 1988. Very dirty but a good cleaning,
professional paint job, adjustment and they work and look like new.
Amazing after 44 years. The Konis on my 67 have been there for 32 years. The early Konis are numbered 1326 and 1327 while the newer
are 1388 and 1389 respectively for front and rear.
Agree with all the comments about Konis, you will not regret it!
Quote from BoSDisplay MoreI am running original (never repaired) Konis on my
Bo can you please tell me what settings you have on the front and rear on your konis
Thanks Mark
If I don't recall wrong they are set at 1.5.
Paul, if I am wrong please correct me.
Paul helped me set them
Is that 1.5 turns from fully backed off ?
Yes,
Mark
Right now, I'm leaning toward replacing just my front shocks with the Gabriel units. They are less than $20 each. Seems very cheap. My fastback has mostly stock suspension and stuff, so unless I'm missing something, this should be a comfortable ride? I don't want it to ride like grandpa's town car, though. I still want to be able to blast some corners when I want to. It's been sitting for a week and it's time to get her back on the road!
