The skirts on several of my pistons are cracking. What causes that - is it just years of wear?
Also, should I go back with a stock piston or look at upgrading?
Jack
Jack
Perhaps age, lots of hard miles, and/or perhaps too aggressive long term timing settings, resulting in a lot of pinging under load.
Years ago I was told pinging was actually the cylinder walls vibrating. Can't speak to the accuracy of that statement, but no question something very violent is going on during each cylinder's power stroke.
Eleven, twelve years ago when I was rebuilding the hipo's engine, I read several articles that supported forged pistons over the hypereutectic alternate for performance engines. So when I did the rebuild, I went the forged piston route. A more expensive choice, but for me it was the correct thing to do. I also went with stainless steel valves because it was the hot rod thing to do.
All of Fords pistons are cast and are really junk and don't last.Any type of hard driving or racing will cause the pistons skirts to crack.Oh I forgot to mention that Ford didn't do a very good job of balancing their motors either.Just upgrade to a set of forged pistons as your motor will be glad you did!
I think a hypereutectic piston can be forged or cast. Compared to cast pistons that would have been used in our cars, even the cast hypereutectic version is way better.
When the original engine in my 66 blew during a SCCA road race in 1973 it was determined the cause was a piston that came apart.
Thanks for the advice and I will definately go with forged pistons.
Jack
I always use forged pistons for my rebuilds as they are superior. The only drawback for a street engine is that they are slightly noisier when cold due to the greater piston to wall clearance required for forged pistons. I keep remembering that Chevrolet always used forged pistons in their high performance 302, 327, 350, 396, 427 and 454 engines. Those engines have not, from what I have experienced, had any piston problems. Chevrolet also used forged cranks which would have been a nice touch for our Hipo 289 engines. A friend of mine did use a Boss 302 crank in his Hipo 289 race engine and kept the 289 configuration by offset grinding the crank to the 289 stroke. I am pretty sure that he said that he used some sort of a Chevrolet rod due to the smaller bearing size from the offset grind.
I used Forged pistons in my rebuild several years ago.
They were only about $80 more then hyper-eutectic....
My stock pistons lasted 127k and only had one cracked skirt.
The bores were running 4.006-4.008 so rather than honing to 4.010 and using 4.000 pistons with 4.010 oversize rings, I opted go the minimum bore at 4.020 and std. rings.
Best of luck on your rebuild........
Mark
I take it your block cleaned at .020 ? sometimes 4.020 is not enough to totally " clean " the cylinder walls and make them uniform... When you go to .020, do you hand fit the rings, or can you buy rings that are correct for the bore size....? do the rings come with the pistons or do you buy the rings separately, and what rings do you recommend?![]()
.020 oversize rings and pistons are definitely available from aftermarket sources and I have had several Hipo 289 engines with that configuration. This gives you a chance for another rebuild at a later time without going too far oversize on your bores. Interestingly Ford never offered an oversize piston or undersize rod bearings for a Hipo 289.
Quote from C6ZZKGT.020 oversize rings and pistons are definitely available from aftermarket sources and I have had several Hipo 289 engines with that configuration. ............"
my Hi-Po engine had the original pistons in it when I bought it in 2000 & was badly needing an overhaul. The cylinders cleaned up well & +0.020 pistons worked/are working great some 43,000 miles later.
I don't understand why folks routinely go to +0.030 pistons without giving +0.020 overbore a chance.
Z.
Unfortunately it isn't only a question of the piston being cast or
forged (although forged is inherently much much stronger).
My Boss 302 had the majority of its skirts cracked after less than 10,000 original miles (a very well known/documented problem in that community). And those original Boss 302 piston were forged-relatively heavy TRW slugs as opposed to our strutted castings.
Skirt design, rod ratio and side loading also play into he equation as well as the eternal quest to lighten the reciprocating weight-which if properly done helps everything especially balancing--as long as you don't crack a skirt!!
Thanks again guys. My engine still had the stock pistons and will be able to go with the 0.020 overbore and that size pistons and rings are definately available and are on order.
Jack
