NOS 1965-1966? FORD 289 HIPO Engine in Crate
  • cool.
    It looks real. It looks like it has all the right parts. The 245 on the tags indicates a k-code motor.
    The address on the tags is in the same town as the seller. It's probably the real deal. The only thing is it's probably rusty inside from sitting all these years.
  • For an old engine, it has a few "shiny" items, like the accelerator return bracket, the bracket's nut, the idle adjust screw and just about everything else associated with the carb. The engine ID tag is in relatively good shape too.
  • Quote from jwc66k
    Would expect the carb to have been covered in plastic, which would have protected those items. A detail that is nice to see and indicates the carb is untouched is the return spring being dyed in blue. All of the re-builders do that piece wrong in zinc dichromate.
  • Quote from CharlesTurner
    Somehow, I don't think so.
  • Quote from dunc289
    Jim, share with us why you don't think so....wouldn't they protect the induction side from debris, etc., ...?:D:D
    Looking at the condition of the engine, rust mostly, and the latest admission by the seller that the engine won't turn over, any covering over the carb would be a trap for moisture, especially in the East, as in Ohio. Ever hear of condensation? To see a "shiny" bracket and other items on the carb, would make me suspicious. If anything, I would assume that the carburetor was added to enhance the sale.
  • Quote from s2ms
    quote:
    ...and the latest admission by the seller that the engine won't turn over...
    Actually he says "also the motor does turn over."
    You are correct.
  • Jim, yes, of course I've heard oof condensation, but I would think it would be somewhat vulnerable to condensation in any case, considering the rest of the engine's appearance... it does seem a very "fresh" carb, thats for sure, I just was wondering if anything could have kept it looking that fresh? Do you think not? Anyone else?:D:D
  • Factory assembly lube will most likely protect the internals, but the heads would have to have a complete disasembly and possibly valves need to be relapped or replaced, the rope seal and timing chain seal would have to be replaced. the intake manifold most likely has rust inside.
    To even try to start this engine without a complete disaembly and a good going over with a scotchbrite on all internal parts and hot tank the block and manifolds would destroy the engine in my opinion.
    Looking at another $500-$1000 over what the winner pays with shipping .
    Possibly $7000-$10,000 total. Too much in my opinion.
    -Scott_
  • Note no chrome dipstick. No rubber on the J hooks. I think the carburetor is not original to this engine. you could get that blue dye look on the return spring with a blue sharpy. I think it has been added. Engine tag has likely been added.
    Also date on the shipping tag appears to be Jan-86.
    No 245K 10 degrees label on the coil. No 289 Cobra powered by ford- High performance labels on the rocker covers. A complete crate engine would have these labels. I think the rocker covers were added at some point.
    Spark plug wires to the distributor would likely not be included. Coil would likely not be included.
    I think this is a remanufactured engine with a lot of old parts added to make it look like a complete factory engine.
    Any thoughts on this?
    -Scott-
  • While I agree it is odd that the engine has such a clean carb - it is not what I would call "pristine". I'd bet it was covered with something.
    For me there are just too many details - like all the hole plugs and wire clips that are correct or similar to photos I've seen - it is legit IMHO. I think the seller may have "wiped" off a few bits - like the engine tag - which make it look odd - but not incorrect.
    Scott - decals on the valve covers are a MYTH - no HiPo Mustang ever came with them - so I wouldn't expect to see them on a factory crate engine either - especially in a '66 vintage from the casting dates he has posted for the engine. Search the archive and you will find this has been discussed here before.
    I would expect to see wires and the coil since these engines were run in before shipment - plus I've seen period photos with similar details.
    Hand written date on yellow tag looks like JAN '68 to me.
    Definitely a nice find - especially for someone needing one for their car.
    My 2 cents.
