New listing by seller cosmotors
BuyItNow set at $42,500
Quote1965 Ford Mustang K Code Proper Car Rare
VIN 5R09K187323 Total miles unknown
This is a super-rare factory K Code Fastback. Originally red, now bronze. This is a number-matching car, including engine block transmission and rear end with original door data plate. Car has the original, ultra-rare solid lifter hi po 289 with correct fan distributor heads, exhaust manifolds, and even the original alternator pulley, the correct Autolite 4100 manual choke sits on top and original Ford high-rise intake put on back in 1969. Date code on intake: 1969. This is the same intake as the Cobra high rise, just different lettering the top loader. 4-speed shifts smoothly and has its VIN stamped on the bottom. Rear end is the correct 9-inch with the tapered ends and the correct snubber and bracket in the differential. These are impossible to find if missing; even the hi po motor mounts are in place. Interior is black Pony with its original 8000 rpm Rally pac. Center console paint is driver quality it should be red. This is a rust-free solid car with only one small blister on the driver’s door bottom even the cowl vents are solid. Extremely rare car. Washington title.
