Quote.......... How do you guys suggest I go about this? I don't want to get black overspray all over the nice white paint job, but masking it will be too sharp of a line. Should I just use a brush with some flat black enamel over the white? I imagine spray paint would have too much pressure to avoid the overspray....
Use a method referred to as backwards masking where the edge of the masking tap is bend back towards itself (no folded!!!!!)
This produces a soft edge rather than the sharp edge like you see on cars above. Paper/mask off the area above (also mask off the front fender edge if the fender is installed) and shot the pinch weld and bottom of the rocker panel with a can of semi-gloss black (rattle can) pressure will be a minimum and you will not get any overspray if you paper the area and point the nozzle the right direction ![]()
Seen owners do this on the show field and in the parking lot - you can do it
