Current API Certified Motor Oil Concerns
  • Here is an interesting article Hot Rod Magazine wrote about the lack of ZDDP in the current API motor oil certification. After reading this, I'm now trying to figure out what oil to use in my freshly reguilt engine. It is apparent to me that I'm going to have to get away from the regular shelf items - perhaps a motorcycle specific oil - I don't know. Anyone have any thoughts on this?
    http://www.hotrod.com/techarticles/e…tech/index.html
    Here is another good article that lists actual test nos. for various oils. It's written for Porche owners, but the info is relevant for our high compression, solid lifter engines as well.
    http://www.lnengineering.com/oil.html
    Gerald
    Edited once, last by 65HiPo (April 16, 2007 at 1:08 PM).
  • This was a really worrisome topic to research when I was building my motor this winter. You figure you can do it the old school way with cam lube and frequent oil changes, then the rug gets pulled out from underneath you.
    EOS is readily available from Chevrolet over the counter and can be used to supplement regular motor oils. I have been running Rotella, but when I went to buy my last batch the dealer told me Shell was going to be changing the formulation and that there would less zinc in future production. I am going to continue to run Rotella and will likely add EOS in the 4oz. size.
  • I just switched to Chevron DELO 400 15W-40 HD oil. I found a couple of older gallons with the CI-4 spec which has a higher ZDDP level than the new CJ-4 spec. As Dave mentions the HD diesel grade oils like Rotella and DELO are being reformulated with less zinc too. I will likely continue to use DELO or Rotella and add the CompCams additive which is much like GM EOS.
    A lot depends on how you drive your car. Since ZDDP is sacrificial, if you drive less than 1000 miles between oil changes the new formulation motor oils are probably OK. Using an HD oil and/or the right additives conservatively is cheap insurance.
    Do a search for "flat tappet" on the Bob Is The Oil Guy website, tons of info there.
  • according to the article above, penzoil 20-50 has .196 zinc by weight. kendall 20-50 per the kendall site has .249 zinc and only has the api service rating of sl, not sm. how much zinc was in the old oil and what api rating would it be? also, saw on another site that BG products MOA oil additive has zinc in it, the black can, not the new blue can that is for new cars. dont know if both products are available.
  • I went with Shell Rotella for break-in and switched to Valvoline VR. The Valvoline VR (according to their techs) has a sufficient amount of ZDDP for valvetrain protection.
  • I have gone to adding GM's EOS (Engine Oil Supplement) to my crank case. It was recommended in one of the articles I read about this situation. I add one bottle to every oil change in my Shelby. I'll go back through and try to find the article and post it here. Recently I have been told that Shell's Rotella T, once ok to use, has now changed their formula also, making it unfavorable to use. Most oil companies have a webb site were they address concerns and make recomendations for our applications.
    Ken
  • I remember hearing, a long time ago, when Synthetics first came out, that a brake-in oil was good to begin with, and then switching to the synthetic after that. The beginning oil is the critical oil and I will try to get an answer for that question.:D
  • I talked to my long time Amsoil supplier, Len Pearson in Auburn, WA, and he confirmed that ALL Amsoil oils were synthetic and were NOT suitable for break-in. They ARE the toughest oils for long-term use, and are stable for long periods of time, [ i.e., long storage]. Any input for break-in oils??:D
  • I called my GM dealer and ask for the E.O.S. They said they had sold all that they had in stock and that GM didnt make it anymore.Does anyone have a part# for it.It looks like we are running out of options.
  • Hi guys.
    Following this post, I got in touch with my cousin who works in the lubricant department of Total USA to see what they had to say about this issue. In short, they are well aware of the growing concerns voiced on many automotive forums related to ZDDP reduction in motor oils. To stay on the safe side, he recommends using the following products which are still over 1000ppm Zinc and Phosphorus:
    100% SYN: ELF EXCELLIUM 10W50 / TOTAL RACING 10W50
    Semi Syn: ELF COMPETITION ST 10W40 or 15W50 / TOTAL ACTIVA or QUARTZ 7000 10W40 or 15W50.
    Also, and as most of you already know, the way you use your engine should also influence the choice on viscosity. The lower the first number is, the easier a cold start will be, although i doubt many of you drive their car in winter. The higher the second number, the better it will hold high temperatures.
    Here's an article published by his department head in the Porsche magazine.
  • Rick, The P/N for the GM E.O.S. is 1052367. GM has not stopped making it. How do I know this?....I work in a GM Parts Department. In fact, I have a couple of cases in stock. List price is $9.29 for a 16fl oz bottle. Hope this helps all of you.... Kevin
  • Kevin,
    I have been using EOS as a supplement and was looking for specific info on use as an oil change additive. Does GM have a recommended quantity when adding to oil changes?
  • Quote from round2K
    GM E.O.S. is specifically used/formulated as an engine assembly lubricate & recommends it only be used for specific purpose. On the back of the bottle it says GM does not recommend the use of this product as an additive to engine oil.
    Edited once, last by kar-nut_old (April 28, 2007 at 9:16 AM).
  • Quote from kar-nut
    :thumbdown:sorry dont think id use anything GM anyway(*&^^%$)
  • I've been using the reformulated Mobil 1 15W-50 for about 15.000 miles now. No cam or lifter wear, no leaks, no smoke, and no measurable oil consumption. The cam is one of the Hi-Po ( spec. grind ) cams available thru this forum a while back
    Z, Ray
    '66 GT-350
  • http://www.lnengineering.com/oil.html
    EOS is not recommended by GM as an oil change supplement because of concerns over emissions controls, specifically early catalytic converters. However; there are many engine builders and restoration organizations that recommend it. The issue of lower zinc levels has been a concern in Porsche and air cooled engine circles for a while.
    Edited once, last by Round2k (May 24, 2007 at 7:39 AM).
  • I found the gallon size of Chevron Delo 15W-40 HD with the older CI-4 specs on the back shelf at Advance Auto. The container was dated June 2006. Later, I found one quart of Delo with the same CI-4 rating in a neighboring city's Walmart. That gets me 5 quarts. My Kar currently has Castrol GTX 10w-40 SL rating purchased around July 2005. Lots of start-ups, but driven less than 100 miles on the Castrol.
