Were there 65 GT kars?
  • My car is NOT a GT and was built Dec 22nd 1964 I think. I thought I read somewhere on here that they did not make any GT cars that early? Just wondering is all?
  • Steve, You are correct that Ford did not make GT Kars that early in production for the 1965 model year.
  • Disc brakes were an available option on all 8 cylinder Mustangs including Hipos. Power steering was available on all Mustangs except Hipos.
  • My car is pretty plain. The only thing it has is the rally pac. I have thought about putting disc brakes on it, but not really sure it's worth it. I have gone through the whole bake system, so they should work fine when I get it on the road. I put a duel master on it is the only change.
  • Quote from stevea
    I went the opposite route during my restoration, adding the factory disk setup. Then for good measure, I also added the 10x2-1/2 inch rear drums. In the 23k plus miles I've put on the car since 2000, there have been a couple of ocassions where I was damn glad I had done the upgrade. Just sayin'.
  • Quote from 65Rangoon
    Part of the reason I did not add disc, was because the car has the original running gear and I did not want to change the originality of the car. Not really sure it's worth it or not? It honestly depends on how much I drive the car too. If I end up driving it a lot, I may change the brakes over to disc.
  • Quote from jwc66k
    You can answer the question yourself - are you going for a "restoration", or are you going for a "drive"?
    I guess that would be a question I answer after I start driving it :) I am so close to having it running, it's frustrating! Driving it is my plan though.
  • Quote from stevea
    If I chose to put disc brakes on the car, is it better to go with stock kind or is aftermarket ok?
    I'd reckon either way is ok.
    I went totally stock as I already had a proportioning valve, stock calipers (which I had to rebuild), FOMOCO dust shields and of course no spindle change was necessary. As I recall what I didn't have on hand was sourced from Stainless Steel Brake.
    Edited once, last by 65Rangoon_old (November 1, 2010 at 2:43 PM).
