What does a casting number C3OE-6329-A on a 289 rear main cap identify it as, anyone seen this before ?.
289 REAR MAIN CAP CASTING NUMBERS
Someone is pulling some's leg. The C3OE-6329-A cap is a HiPo crankshaft front main bearing cap -- but is marked with an arrow and a number 1. The rear cap is marked C3OE-A. The standard 289 rear cap cap is marked C2OE-B.
Bob i sent you an e-mail with pictures of the main caps i have that have C30E-6329-A cast into the rear cap .regards chuck.
I've got an early 63 dated Hipo motor with Hipo caps and C2OE-B rear main that I just pulled from an original car?
The C2OE-B is a standard 289 marking. Do you have a picture?
I have a set of hipo caps that has the rear cap marked with a '4' and a stamped 'D'. The regular #4 cap also has a '4' but with an arrow. and the # 2 cap has C3OE, a '2' and an arrow. 1 & 3 are typical with '1' & '3' and arrows.
This is getting very confusing as these tend to stray from what is considered to be the "norm". Pictures of all of these posted here would be a real education for all of us.
Here is a set 1-4 main caps listed as 289 Hipo's that sold on eBay recently with the numbers & arrows on the center & sides of the caps.
[Blocked Image: http://i6.ebayimg.com/03/i/000/be/a3/2a2e_1.JPG]
Here are pictures of the ones Chuck was referring to:
[Blocked Image: http://www.fordsmallblock.com/Pictures/C3OE-6329-A-1.jpg]
[Blocked Image: http://www.fordsmallblock.com/Pictures/C3OE-6329-A-2.jpg]
I have never seen anything like it.
Here is a picture of a standard 1963 small block (left) and 1963 289 HiPo (right):
[Blocked Image: http://www.fordsmallblock.com/Pictures/HiPo-caps-1.jpg]
Here is a picture of the 1968 Mexican 302 (left) and a later 289 HiPo (right):
[Blocked Image: http://www.fordsmallblock.com/Pictures/HiPo-caps-2.jpg]
This is very interesting. Chuck's rear cap and the Mexican cap have the same 6329 casting number. I have a set of Mexican caps but they only have the date code on the rear cap.
Is it possible they are late HI-PO or early mexican caps or a casting mistake at the foundry ,i would like to talk with a foundry worker who was there when this stuff in production .
Chuck
Since we last talked the other nite I have given it some thought and
here is what I came up with for the debate:
If a person ruined a HiPo maincap in the late 60's is it possible that Ford would only sell a full set of caps and marked the rear main with the full PN rather than a partial number as came from the factory. Would make sense that Ford would need a full number for the service part(s). Do you think these are service caps if there was such a thing. Also could have been a very small run of 25-50 sets. I think this is more possible then any Mexican connection. How bout this for a pitch-very rare Dragon Snake caps!! Ray
Lots of variation among foundries. Look at last example pic with stamped 3 rather than cast 3. Ray
TOOLBOX if you can care to post pics of your caps they seem equally interesting. Ray
edit: sorry, I've tried and tried to post a pic, but it always shows up HUGE. I don't know how to make it work.
I stand corrected - the regular #4 cap has the 'c3oe', and #2 has what looks like a date code '17B7'
Here are your caps, Karl:
[Blocked Image: http://www.fordsmallblock.com/Pictures/Karls-HiPo-main-caps.jpg]
I have worked at ford dealerships for the last 25 years and i can say that it could be possible , if there is a non mexican service replacement block out there in K land a picture of the bottom end would be worth a thousand words, Chuck.Quote from poboy427Chuck
Chuck, do you know the origin of your caps? Is it possible the 1-4 caps are Mexican with the dates ground off? I did some image analysis on the pic of your caps Bob posted using software I have available at work and find "possible" evidence of what's left of the date code "pad" usually seen on Mexican caps on cap#2. Also on caps 3 and 4 are possible traces of the cast "screw" seen on the Mexican cap pad. This doesn't explain the rear cap unless it is a very early (transition?) Mexican cap. Dave
These caps were part parts lot i purchased some time ago and they were the only caps in the lot,i looked them over very close and see no indication of grinding or shot peening to remove metal on the caps ,all 5 caps were dirty and tarnished ,all i did was clean them with a wire wheel .Quote from s2msChuck, do you know the origin of your caps? Is it possible the 1-4 caps are Mexican with the dates ground off? I did some image analysis on the pic of your caps Bob posted using software I have available at work and find "possible" evidence of what's left of the date code "pad" usually seen on Mexican caps on cap#2. Also on caps 3 and 4 are possible traces of the cast "screw" seen on the Mexican cap pad. This doesn't explain the rear cap unless it is a very early (transition?) Mexican cap. Dave
