Vapor Locking ???
  • My '65 Koupe seems to be having intermittant fuel starvation. I have not driven it a lot (maybe 300 miles) since the engine rebuild and took it to a show about an hour away yesterday. It rand fine going to the but on the way home it seemed to vapro lock on me. Part of the trip was on a curvy road and involved a fair amount of heavey acceleration between curves and it ran just fine even when I would really get on it. Then we (traveling sith some in Mustang club) got on the highway and when I would reach cruising speed (70mph) it would stall then start then stall then start etc. like it was starving for gas. I was showing a littloe over 1/4 tanks and the gauge seems to be fairly accurate. The car never died but I had to pull to the shoulder a couple of times and pump it a little to keep it running then it would smooth out and fun ok until I reached scruising speed again. We pulled off and I filled the tank and started up again and it sputtered again when I first got back on the highway but then it settled in and I could cruise and even ran it up to 80 - 85 without any further problems all the way home (about 25 miles).
    Today I pulled the fuel filter and it had some sediment in it but not too terribly bad. However there was a fairly good amount of sediment in the bottom of the canister (maby a half a teaspoon) and it was mostly a dark brown power sith something mixed in that appeared to be brass shavings - not a lot but there none the less. Has anyone else experienced this and what did you do to fix it? Is what I describe from the dirty fuel filter or is it vapor locking?
    Jack
  • In my experience, dark brown crud is typically caused over time by really old stinky gas. Your hard fuel line may be comtaminated or rusted to some degree and as fuel travels to the pump, that amber crud is washed off the inside of the fuel line.
    You may want to blow out the hard line, and pop the top on the carb to see what is laying in wait in the fuel bowls. Might also be a good move to drain the fuel tank and see what is resident, as well as remove the tank sending unit to see if that filter is contaminated as well.
    • Official Post
    Also make sure that the fuel hose that connects to the fuel tank sending unit is fresh. An old hose can get cracks that do not leak fuel but will cause the pump to suck air rather than fuel. Everybody has had this problem at one time or other with a drinking straw. :)
    -Fred=
  • we just replaced my son's brand new fuel pump!
    had less than 100 miles on it.
    car would run fine for about 5 minutes
    than would 'dog' out.
    checked lines = ok
    installed new fuel pump = runs great!!
    iowa
  • Quote
    "................... Today I pulled the fuel filter and it had some sediment in it but not too terribly bad. However there was a fairly good amount of sediment in the bottom of the canister (maby a half a teaspoon) and it was mostly a dark brown power sith something mixed in that appeared to be brass shavings - not a lot but there none the less. Has anyone else experienced this and what did you do to fix it? Is what I describe from the dirty fuel filter or is it vapor locking?
    Jack
    you have really answered your own question. ANY debris such as you describe indicate your ENTIRE fuel system is on need of examination and likely replacement. The most likely place to start is the fuel tank. Drain it and stick a mirror (on a telescoping rod) up into the tank from the sending unit hole. Even tanks that are fairly new can be rusty. I've seen brand new Mustang tanks that were covered with powdery rust inside.
    If rust is found, don't waste your time trying to seal it. Buy a new tank, and new fuel lines.
    Z.
  • I ended up replacing the fuel pump, the fuel tank, and blew out the lines and all seems well and happy! Thanks for the advice from all who responded. Now I have another part to keep clean - the new fuel tank (I didn't worry too much with the original as it was undercoated)!
    Jack:)
  • There is a major, major problem with gas at the local pump. I recently had a carb that had not run on the engine since last fall. The rebuilder said the residue was so profoundly prevalent that it took a week soaking and extreme effort to remove jets. Conclusion; the gas may not last a couple of months. For storage then, run the carb dry, and drain tank or, possibly, use PRI-G, a stabilizer. I discovered a local wholesaler that sells ethanol-free gasoline retail for a few cents more a gallon, and I will be using it in my Mustangs. regular use of the daily driver can live with the pump gas. Anyone else have a similar experience?:D:D
  • I don't take any chances with the ethinol gas...I always use the 2 year dose of Sta-Bil with all gas I put into my car-I believe that my recently rebuilt/restored fuel pump and 4100 carb were done with materials that will be ok with this crap gasoline we are forced to use today.
    Something else you might want to consider is the addition of a spring in your lower radiator hose....these cars originally had them and the repro hoses don't come with them but the springs are available separatly now, I had a simmiliar problem like you described and my engine was running a bit warm, I added the spring and all is well now.
