Hi all,
I'm new here (at least as far as posting on the board), and I have a problem I need help with. I just bought '65 K convertible and the car is just beautiful. The only problem is at 60 mph the car vibrates badly. I've had the alignment checked, the wheels balanced and the inner and outer wheel bearings replaced (which I doubt needed replacing), but the car still vibrates at 60. I now believe it's either the wheels or the tires. The tires are radials, and the car has the period correct styled steel wheels. At this point I suspect the wheels are out-of-round, but I would prefer to not go to the expense of replacing them if that turned out not to be the problem (again). Does anyone here have any insight to this problem?
Kerry
