It seems that I read a post somewhere about welding a Z bar to make it stronger? Is there any information on this? Thanks
Z bar question?
It is a pretty common practice to weld gussets to the bar. There are some folks that swear this is unnecessary if the pivot bushings are properly cared for and lubricated. I've had enough of them bend through the years that I default to the gusset and install a zerk fitting on the bottom so it can be lubed.
Quote from round2K
It is a pretty common practice to weld gussets to the bar. There are some folks that swear this is unnecessary if the pivot bushings are properly cared for and lubricated. I've had enough of them bend through the years................"
plenty of them bent within a few months of the cars delivery when new (can't blame cheap reproductions or Chinese steel for that). I've been reading the new SAAC registry and am seeing MANY warranty claims and repairs for bent or folded up Z bars on the '65 & '66 GT-350's.
Mine is gusseted by the tube and has a steel reinforcement band the length of the "arms". Opentracker did it for me when I bought one of his rollerized z bars set ups.
even if I had the original z bar I would still have it modified.
http://www.opentrackerracingproducts.com/clutchrods/
Z.
would anyone happen to have a pic of a bent one?
we are installing a new Z bar on my son's '66 right now.
maybe i should weld in a gussett?
iowa
I had a K convertible back in the '70's and I had one bend on me when I was pulling into the garage. Had to shut the motor down and jump on the brakes to avoid going through the wall! Started gusseting them back then on the recommendation of the local Ford parts manager and they were over-the-counter Ford parts. It was a very common issue.
Quote from round2K
I too had a K Convertible back in the mid 70s-it was my FIRST car-I paid just $500.00 for it and had NO IDEA what it was: Anyway when I installed a super-strong Zoom racing clutch setup my Z bar bent under the pressure and a local welder fixed it with a somewhat crude gusset-it was very ugly but it worked! I won't do my present one that is original until/if it bends....(I'm running THE original clutch setup that has been rebuilt)
could s.o. post a picture of the correct K
equalizer rod/bar and Z bar?
i'm not sure NPD has it pictured correctly
iowa
Quote from iowa
iowa
Pictures of the Z Bar (and all the other unique Mustang HiPo parts) appear in the book: The 289 High Performance Mustang by Tony Gregory. Consider purchasing a copy of this valuable reference manual, and you'll be supporting this site by your purchase. LINK TO PURCHASE BOOK HERE
Would someone who has done the gusset modification mind posting a diagram with recommended gusset placements and diagram where to put the zerk?
BTW, in case anyone is thinking to ask, I bought the Gregory book and the Mannel book as well. Always try to support the troops.
Much obliged
I will try to take a photo later today (it's Feb 14th and may not get to it). Unsure if it will reveal anything as Z bar is installed and not to visible.
Z.
Quote from iowa
iowa
http://blog.virginiaclassicmustang.com/2011/02/1964-1…g-289-high.html
