• The scenerio goes like this:
    - Somewhere on the assembly line, the tie down plates were installed. The installer grabbed two, some addition hardware if needed, and put them on the car. I think before the exhaust system was installed on a Mustang as access to the bolts is restricted.
    - When the finished car was put on a truck or train, two chains were attached to the plates and tightened. The front was chained down via holes in the frame rails (per a former delivery driver).
    - At a distribution point, the cars were placed on another truck to go to a specific dealer and chained down again.
    - As part of dealer prep, the dealer was supposed to remove the tie down plates and return them to the assembly plant for reuse. We know that didn't happen with any discipline. I would think that cars sent overseas would retain the plates as returning them would not be cost effective.
  • Mine were left on.....4/26/66 dearborn Kar.
    According to my Window Sticker, it was delivered via CONVOY to Duthler Ford in Grand Rapids, Michigan. So I don't believe the Tie downs were ever used.
    Mark
  • The term CONVOY is referring to the truck that delivers multiple cars to the dealers and the truck would utilize the tie downs.
  • i've always been a sucker for basket cases!
    s.t. i'll post a picture of my 1st car...'63 VW beatle
    and how it looked before i restored it!!
    the tie down on the right is still on my car!
    it too, looks like s.o. tried to hack saw through
    the rear part of the rail where it is attached...
    i wonder if s.o. was finally trying to remove them
    and couldn't do it by removing the bolts etc.
    probably will never know
    iowa
  • what are the MCA judging standards for these tie downs?
    if one but a 'K' car new
    and these had been left on,
    would there be reduction of points?
    iowa
  • Quote from CharlesTurner
    They're not required for concours judging, but if they are installed, they have to be the correct finish with correct hardware.
    Being that the tie down plates are a "reused" part, have little if any documentation and were installed with what hardware was available, scratches, rust and mismatched hardware would be the norm for factory installed items. That being said, I would recomend that if installed, the associated items be "clean" at the least.
  • Charles:
    Regarding your comment on appropriate finish for concours judging, am I reading correctly that some were found painted, while others were not? Is this another example of Ford's consistency in manufacturing?
    This would beg the question of how to judge their appropriate finish. Are the plates considered "correct" by MCA if they are painted? If so: gloss black, or satin?
    Or, are they allowed to be parkerized?
    I hope the MCA reply is NOT "natural only." It's tough to maintain a bare metal finish for a few points. And, from the above information, there seems to be some variance in finish.
    Great information!
  • Quote from rds289k
    Charles:
    Often a differences in supplier - so the next question would be - Where was your Mustang built? (for the correct response)
    Edited once, last by J_Speegle (November 10, 2010 at 10:31 PM).
