FS: 1966 K-GT Convertible
This Will be listed on eBay starting Thursday the 24th. This is a heads up so tell your friends.
Please call for price. Serious buyer's only! Please call Orlando Mustang @ 407-688-1966
Options: 289 K Engine Serial # is Stamped on Block & Trans, 4 Speed, "Working" AM-8 Track, Rally Pac, No Power Steering, Deluxe Pony Interior, New Power Top with Folding Glass, 4 Wheel Disc, Dual Master Cylinder, Styled Steel Wheels
Interior: All New Interior, Aqua and White Pony Interior, Pony Steering Wheel, New White Top
Exterior: Color Changed from White to Tahoe Turquoise, New Wind shield, Replaced Front Fenders & Rear Quarters
Engine Compartment: Numbers Matching ,ENGINE, TRANS and VIN, Dyno Tuned @ 318hp at the Flywheel, Motorsport Pulleys, Aluminum heads and intake, 600 Holley, has Tri-Y Headers (HPC Coated), Wrong Volt Regulator, Alternator, Air Cleaner, Dual Master Cylinder added, Correct 289k Distributor, does not have original CARB, Intake, Fan, Radiator, Orig Limited Slip, 9" Rear, HD Steel Flywheel, , Blow Proof Bell Housing
Mechanical Condition's: All New Suspension, 1" Sway Bar, Dyno Max, Mufflers, Tri-Y Headers, Rear Stainless Steel Brake Kit, Front End Never Aligned, Has Close Ratio & Wide Ratio (Now Installed), Center Force Clutch
Rust History: Car is from California, Original Inner Fender Aprons, Slight Repair Left Hand Drivers Foot well
Documentation: Michigan Title, Restoration Receipts, Matching numbers on inner fender and Door Data Plate, Driven 100 miles since restoration, Restoration finished about 2003.
*Mileage is not confirmed could be 60,986 or 160,986
VIN # 6R08K194906 / Interior Color: White / Exterior Color: Aqua
Engine: 289 / Transmission: Manual / Mileage:60,986*
DSO: 87 Body: 76B Color: M
Trim: 67 Date: 06E Axle: E Trans: 5<font face='Verdana'></font id='Verdana'>
[Blocked Image: http://i2.photobucket.com/albums/y16/OrlandoMustang/66%20K%20GT%20Conv%20%20Aqua/IMG_4049Medium.jpg]
[Blocked Image: http://i2.photobucket.com/albums/y16/OrlandoMustang/66%20K%20GT%20Conv%20%20Aqua/IMG_4053Medium.jpg]
[Blocked Image: http://i2.photobucket.com/albums/y16/OrlandoMustang/66%20K%20GT%20Conv%20%20Aqua/IMG_4056Medium.jpg]
[Blocked Image: http://i2.photobucket.com/albums/y16/OrlandoMustang/66%20K%20GT%20Conv%20%20Aqua/IMG_4057Medium.jpg]
[Blocked Image: http://i2.photobucket.com/albums/y16/OrlandoMustang/66%20K%20GT%20Conv%20%20Aqua/IMG_4058Medium.jpg]
[Blocked Image: http://i2.photobucket.com/albums/y16/OrlandoMustang/66%20K%20GT%20Conv%20%20Aqua/IMG_4059Medium.jpg]
[Blocked Image: http://i2.photobucket.com/albums/y16/OrlandoMustang/66%20K%20GT%20Conv%20%20Aqua/IMG_4060Medium.jpg]
[Blocked Image: http://i2.photobucket.com/albums/y16/OrlandoMustang/66%20K%20GT%20Conv%20%20Aqua/IMG_4072Medium.jpg]
[Blocked Image: http://i2.photobucket.com/albums/y16/OrlandoMustang/66%20K%20GT%20Conv%20%20Aqua/IMG_4088Medium.jpg]
Edited by - orlmust on 10/01/2009 15:46:54
