am i right to presume that it will be cheaper to find a good K code in the US as apposed to Australia? Will continue to look . with the help of you guys it might just work, I figured the car would have to be in California because the people that can help ship out of longbeach so I'm trying to cut my costs , need to be an original K car auto , wish me luck
not giving up
Good luck!!!!!!!!
well done rohan
I think this car has a non- "C" trans, I looked into it before, if I am not mistaken. Check very carefully, ask a forum member to inspect it. It is a very decent price if the TRANS is correct, C servo C-4's are very hard to come by, IMHO. Touch base with me if I can help.
Cheers.
An auto Trans. in a K Code. Wouldn't that suck the fun out of driving a HiPo?
Quote from tony289k
Not as much as knowing it costs a buck every time you hoof it
Very few who have experienced an original, well setup K code with the proper C servo C-4 trans would say it sucks. They were very different to drive than a stock C-4.
Quote from dunc289
Amen to that, brother!
Is that bracket on the frame for the pinion snubber correct spec or not?
Quote from dunc289
The only part I don't like is that you never know when it will shift, as in RPM. Other than that, the 'Bow Tie' crowd pretty much are in awe.
Quote from dunc289
I've driven a '66 GT350H car and would have to agree!! Much different than driving my '66 289/C4 convertible.
Incidentally, my 66 K fastback is an original C4 auto car but I've yet to drive it since it's still under restoration.
Quote from 66gtk
True, usually you can count on a shift (hard) at tire breaking RPM as long as you keep your foot down. To make it shift when you want, just ease up on the gas a little and it will shift pretty much when you want it to. That's been my experience in a GT350H.
Quote
This 'ease up on the gas a little' thing - what a strange concept. I'm refering to when I don't ease up, it shifts at different RPMs, all very high (gee I like that sound). It could be due to different temperatures or some other external reason. It is different than a manual transmission that you can control the shifting points.
Didn't mean to upset Auto owners. I've owned auto's myself and loved them. However, I'm glad my Hipo is a manual. Especially when I am throwing it around those Mountain road bends.
With the car moving at a ' good' rate, the shifter in "low", and a 3.50 or 3.70, even 3.90 rear ratio, it will stay in that gear, second, through a wide speed range for the twisty, winding bits. While noone will claim it is as good as the four-speed under these conditions, its still quite exhilarating, and easy on the clutch leg in heavy traffic.
