water neck/inlet leaking???
  • Hello, I am battling a leak on my water neck housing. I have replaced the gasket several times with the same results. The leak is on the bottom portion of the water neck and the water/coolant pools in the valleys of the front timing cover. No leak from the timing cover. Any suggestions? The surfaces of the intake and water neck appear to be fine, no waves or anything. I am going to buy a new water neck and try this next, but would like to get some input before I start. Thanks.
  • Have you put a straight edge across the mating surface of the intake and the surface of the neck? One or both of the two may not be perfectly flat. Also, hopefully you're not using a chrome water neck. They always seem to leak.
    Greg Z
  • we just discovered that ours leaked too!
    i had filled up with antifreeze
    and here it came dripping out the bottom bolt hole also!!:thumbdown:
    we took it off
    cleaned the surfaces (some pitting)
    used the straight edge check
    new gasket and liberal black silicone
    and let dry overnight
    will see today if it leaks
    hopefully not as we don't want to replace
    the aluminum 'edelbrock' intake manifold'
    will let you know what happens
    iowa
  • In my humble opinion the chrome water necks are crap.
    Mine leaked as well and it didn't stop until I replaced
    it with an original. Also make sure the thermostate fits
    into the recessed area on water neck or in the intake.
  • Quote from BoS
    Also make sure the thermostate fits into the recessed area on water neck or in the intake.
    That falls in the catagory of "oops, damn", if you tighten the water outlet with the edge of the thermostat in the way.
  • speaking of leaks
    we saw the tell-tale
    pool of antifreeze in the inner pulley!
    man....the pump was only out for a few months
    and the seal must have dried out
    any chance of it stopping on it's own
    or is replacement always necessary?
    iowa
  • it turns out
    that it was probably overflow
    out of the radiator.
    our rubber tube only extends
    down to the upper level of the frame
    and we had filled the radiator to the cap!
    it doesn't leak now
    iowa
