Any tips on how to adj. correctly.
dual points
First off I think you just adjust each one separately to the specified gap which if I remember right is 0.16?? someone will correct me if I'm wrong.
The Shop Manual range is .019 ~ .021 or 30 ~ 33 degress of dwell.
I've always just adjusted each set to .020 with a gap gauge and never had a problem.
If you go with a Pertronix carry a spare, or your original dual point setup in the trunk. From first hand experience a Pertronix can die suddenly. I know several people who have had a Pertronix die as well.
I have had a Pertronix in my K for 8 years now and have not had any issues with it yet - it is still the best $60 I have spent on my car. I do however carry a new spare Pertonix that I picked up cheap from a friend who decided to stay with his dual point setup, just in case.
Jack
I have installed a number of Pertronix units in customers cars. I have had 2 failures of the Pertronix units however my own Kar is still working well. I do carry the point setup in the glove box as a backup, though.
Have the pertronix on my K for five years now with no problems.
thanks for input
Do you use 2 pertronix units in place of the dual points??
they offer 2 models for Ford, single point conversion, and a dual point conversion. I have the Pertronix I dual point conversion. I assume the newer Pertronix II has the same offerings.
Quote from 6hypo5conv
You use only one Pertronix unit. The difference between the single and dual point application is the breaker plate.
Quote from 289kfordthey offer 2 models for Ford, single point conversion, and a dual point conversion. I have the Pertronix I dual point conversion. I assume the newer Pertronix II has the same offerings.
The Pertronix II does have a dual point conversion but it can't be used with the steel core HiPo spark plug wires.
I bought Pertronix for my 67 many years ago
and it didn't do much difference except that
I didn't need to perform the adjustments.
Bought a Pertronix coil and saw some performance
difference. Finally I bought Pertronix wires
and that made a big difference in comparison with
Marti's HiPo steel core ones. I can really
recommend to use all three together. The performance
and throttle response improved a lot.
I added a Pertronix to get rid of the hassles with points closing up over a period of time. Now it even seems to start easier although I do not see why the Pertronix unit would help that. Everything else in the ignition system is Ford.
Quote from BoS
I bought Pertronix for my 67 many years ago and it didn't do much difference except that I didn't need to perform the adjustments. Bought a Pertronix coil and saw some performance difference. Finally I bought Pertronix wires and that made a big difference in comparison with Marti's HiPo steel core ones. I can really recommend to use all three together. The performance and throttle response improved a lot.
Good points Bo (no pun intended). Now if we could only convince Pertronix (or anybody) to make a high quality yellow top coil and plug wires that look like Marti's HiPo steel core ones we may have a winning combination.
