Is there someone I can send my original water pump to to have it rebuilt/restored?
Water Pump rebuild??
Most guys contact their local Napa or preferred auto parts store and have it sent out for rebuild. You also might check Hemmings for rebuilders.
On Ebay you can find The Water Pump Man.
He restores them. Also carries the correct 6 blade
impeller.
Automotive Friction in Oregon; awesome service. They've done three pumps for me and had them all back to me within a week and they came out beautiful.
How much was the cost?
It was around $60. (503) 855-3670 - ask for Lisa Cejka.
Another vote for Automotive Friction. They rebuilt a C6OE pump for me several years ago. As Dave mentions their service was excellent.
Can any of these folks replace broken off hose fittings on the housing??
Rick, I sent you an email on this.
Quote from 6hypo5conv
I'd also like to know the answer to that as I have one hi-po pump that has that problem.
Charles, is your aluminum?
Charles, I have seen them repaired with boring and sleeving if you have both parts. If you give me your needed date code, I may have one.
I have plenty of water pumps. This one has a hi-po impeller on it, will just take it off.
Charles,
Do you have any March-April 65 pump core available
for sale? Doesn't need to be a hipo.
Would rather hold onto the ones I have now until I finish some of the restorations I'm working on. Fred probably has some for sale.
I Have three early aluminum ones. I'll check the dates.
Mark Vasquez
Mark,
I would be intereseted in a 12/64 or earlier core if you have one.
I could use a early C3 part numbered one with Jun.July or Aug. on it and don't really need to be Hipo.Also could use a 7/64 pump also the same?
I could use a C3 too. Not picky on the date.
Larry
