• Well its time to clean off another shelf. I have the following bell-housings forsale at 75.00 each plus shipping. They will need to be cleaned up and all are aluminum C5DA-6394-B. I can bead blast your purchase for a small fee if you wish.
    10/64
    2/65 one bolt hole has a little section missing but will not show with a bolt in it.
    3/65
    5/66
    6/66
    7/66
    2/67
    Edited once, last by SixT5HiPo (October 19, 2006 at 10:42 PM).
  • Bo,
    If it's on the car you won't see it, the date is cast on the flat face that the tranny bolts to. The date is only the year (65, 66, etc.) and looks much like the date you see on the timing chain covers. On my original there is an oval FoMoCo logo and Sheffield logo in the same area.
  • where are you finding the month date code? I am only seeing the year on mine.
    Z.
  • The date can be located on the flat spot usually to the lower left of the hole for the transmission. There will be a circle with the year cast into the bellhousing. Along the outside of the circle will be one to 12 raised dots which represent the months of the year. One being January etc.
    Ken
  • thanks Ken, now I can, er, connect the dots... (not necessarily a political message)
    Quote from KPHartley
    Ken
  • Quote from CharlesTurner
    All 4 speed 289 bellhousings were the same, hi-po was not unique.
    3 speed used the same bellhousing as well if I'm not mistaken. Only difference would be 5 or 6 bolt depending on your block. Oh, and maybe date code and casting number... The hipo flywheel was not physically larger than a standard 289 flywheel.
    Edited once, last by 66kgt (October 31, 2006 at 9:51 PM).
  • Sam, I have been getting most emails that I send through this forum bounced back as well. The email address is usually correct so all that you need to do is resend your email to the email address that is listed in the bounced email.
