http://cgi.ebay.com/ebaymotors/196…tem150223545997
The images aren't too clear, but they look correct.
Boxes don't appear to be FoMoCo ones ![]()
We will see as I bought the item.
Hi Bo, I will be curious to see what this turns out to be. I was thinking about this too so emailed the seller, he said it had the threaded top and C5ZZ stamped on the body, not C5AE. Dave
Have ? on this pvc valve, on a 65 hipo shouldn't it have a push on type hose connection with the spring clamp to hold it on thanks Otto
I'll inform you guys when I get it.
The picture was kind of poor but
it looked like it had no threads.
The guy's ad said pvc valve instead of
pcv valve.
I believe that part number is the push on. Mannel's book has part numbers for all of them.
QuoteI belive that part number is the push on. Mannel's book shows all three types of valves on one page.
It gets a little tricky with the part numbers on these. I have two NOS valves in FoMoCo boxes. One has a C5ZZ part# on the box and C4ZE engineering# stamped on the valve, it is a threaded type. The other has C5AZ on the box and C5AE on the valve, it is the push-on type with the hex base.
The C5ZZ valve is definitely a screw in valve as I have several NOS ones in stock. They are listed in the 1965 bound Ford parts book as fitting 260, 289 and 289 Hipo engines. The C5AZ valve is also listed for the same engines. I would say that the C5ZZ one is probably the ones used on the early 5 bolt versions with a 378754-S 90 degree adaptor fitting for the PCV hose.
Got the PCV valve today and it's the treaded type.
The marking on the valve itself is C5ZZA and on the box
C5ZZ-6A666-A. I am doubtful it's an original Ford piece.
The box does not say Ford or FoMoCo anywhere.
Bo,
I have seen a number of these GYPO valves sold on Ebay. The simulated Ford packaging fools a lot of people.
Well, you learn as long as you live, I guess.
Hope the picture wasn't blurred on purpose
in the auction. Otherwise exactly as advertised
so I should have asked before bidding.
Will use it on my Feb. 65 C-code. Fortunately,
I already have an original on my 65 GT350.
Dang! Sorry Bo.
I just received an item I bought from this seller, zul25. It was described as "THIS IS A FACTORY NOS PIECE, I THINK. IT HAS A RECEIPT THAT WILL COME WITH IT THAT SHOWS IT WAS SHIPPED TO DOWN'S FORD. IT IS A VERY NICE PIECE THAT LOOKS NOS"
I should have asked questions because it was a repro. I rusted it was NOS as he has NOS items listed. Shame on him and me. Just a little heads up if you do business with this guy.
I also had problems with zul25.
Over-charged me $30 on shipping, sent a repro part as NOS and one item was used that was advertised as NOS.
Charles, Did ZUL25 try to make it right for you?
Here is another PCV from the same guy. Picture and clear this time at least.
The picture is clearer but he still describes it as a "factory NOS piece".
It is definitely a non Ford part or a GYPO as we call it in the business, as the description on the box begins with "replaces". Ford never did that. It is an earlier simulated Ford packaging. Sometimes they will have a real Ford part in the box but most of the time it is a substandard knock off. There are a lot of simulated Ford packaged parts on Ebay being represented as NOS. Sometimes the sellers are unaware of the difference and change their auction after I let them know however most of the time it is buyer beware.
The Buy It Now price has been reduced to $20 from
$40 so he probably has read this tread.
