1966 K Automatic GT Coupe
  • 1966 Mustang ‘Kcode’ GT Coupe
    For sale, 1966 Mustang ‘K’ code GT Coupe. This is a real GT, not a dealer or owner made GT (the original build/buck tag contains the code PIO (Performance Image Option). I purchased this car in May 1997, after a total restoration it was road worthy in the late Fall of 2003 but leaves the garage only occasionally and only if the weather is right. I have driven this car about 1700 miles since it was completed.
    A lot more pics here >> http://community.webshots.com/user/kcode66
    Here are some of the details:
    BODY:
    Initial major body work by Gelsi Mustang, a very well known Mustang restoration shop located in Vineland New Jersey in December 1997. Car had paint media blasted off. Final body work and paint (Candyapple Red ‘T’ code) also by Gelsi in 2002. (Detailed receipts)
    ENGINE:
    1965 block(no vin), 1967 Hipo heads(19 on both heads). The cast headers, Harmonic balancer(reconditioned by Damper Doctor), distributor are 1965 parts. The Autolite 4100 is a clone built by Pony carbs (purchased Aug. 1997), sits on a Ford Hi-rise aluminum intake (C90X-9424-8) that was on the engine when I bought the car. Engine rebuilt by Alderman Automotive, New Castle Delaware, April 2005.
    Engine was bored .030, heads were cut for larger valves, relief port work on the bowls, Tri ‘Y’ jet coat headers. (Detailed receipts). Bollman Racing Dyno services: engine produced 305HP, 284lbs Torque, Dyno sheet available on request,
    TRANSMISSION/DRIVE TRAIN/SUSPENSION:
    This car has a Ford Factory C4 Automatic, with the 'C' servo. Transmission rebuilt by Transmission Specialities, Aston Pa. August 2000. Car came with original Ford 9” rear, 3.50 ratio (Rear Tag WCZ-S). Currently, the car has 3.89 ratio installed, the 3.50 is stored in a case. Car has the Shelby 1 ¼ front drop, Konis all around, new 5 leaf mideye rear leafs and new pitman and idler arms as they installed on the GT 350’s. Car had incorrect driveshaft, so I had it cut to size and balanced.
    INTERIOR:
    The car had a Pony interior when I purchased it, it should be a standard interior. I replaced most things because of wear (carpet, door inserts, headliner, dash pad, front seats and panels next to rear seat) except for the rear seat and glove box door, New heater core, heater box cleaned and rebuilt. Steering wheel rebuilt by Bill Herndon, Gaithersburg Maryland.
    Door Plate info:
    VIN 6T07K211629
    Body 65A (Hardtop bucket seats) Color T (Candy Apple Red)
    Trim 26 (Black w/black) Date 22B (Built Feb. 22nd 1966)
    DSO 16 (Philadelphia) Axle 5 (3.50 rear) Trans 6 (Auto)
    Build/buck tag info:
    D – Dealer order
    22 – Rotation Number
    15 Welding station
    B22 – Feb 22 (a projected build date)
    65A – Body type (Coupe with standard interior) Note, Car had a Pony interior
    in it when I bought the car, when I restored it I used all Pony interior parts except for the rear seat.
    T – Exterior color
    26 – Interior style and color
    PIO – Performance Image Option (GT this year)
    6T07K211629
    This car was built at the Ford Metuchen plant in New Jersey.
    ADDITIONAL DETAILS:
    Pictures of all 3 fender Vin numbers, buck/build tag and door tag.
    New front windshield
    New brake, transmission and fuel lines.
    New Altenator
    Master cylinder bronze sleeved by Apple Hydraulics
    All new wiring harnesses in engine compartment.
    All original style hose clamps.
    Am radio works
    New instrument bezel
    Sun Tach installed
    New exhaust system, Flowmasters and shorty h-pipe
    Original mileage cannot be documented.
    Harmonic Balancer reconditioned by the Damper Doctor
    New rear axle bearings and seals, AMK body bolt kit
    New gas tank, trunk mat, spare tire cover over a full spare on a styled steel wheel) and jack bag.
    New 3 row radiator
    NOS Battery Apron, NOS front and rear bumpers, NOS rear taillight bezels, NOS front fenders, NOS driver side rear quarter, NOS GT exhaust trumpet tips
    Doors are from a 66 Shelby fastback, stored for 27 years, no rust
    Rear brakes totally rebuilt, front brakes are disc, the passenger disc is from
    a 1967 mustang, same brake, only difference inlet line is 7/16 vs 3/8 for 1966.
    2 of the original styled steel wheels and 2 new with BF Goodrich radial T/A’s.
    95% of all parts were purchased by me, receipts for most
    Car entered in 2 shows, 2 first places.
    Extra parts going with car:
    Car cover, extra instrument panel with the gauges, rear quarter window regulator and numerous bulbs, clamps etc, All the parts that were removed/replaced from the engine rebuild, water pump, rockers, lifters, pushrods, springs, guides, cast iron headers, ‘H’ pipe, extra rebuilt heater motor. GT foglamp and foglamp holder. Also, a number of books/shop manuals including Jim Osborn’s Body, Engine, Electrical and Interior.
    I will sell the car with either 1 set of 15x7 Torq Thrust ‘D’ wheels with
    BF Goodrich radial T/A’s or if you want the original styled steel wheels with BF Goodrich radial T/A’s
    MANY DETAILED PICTURES OF ALL RESTORATION PHASES AND VIEWS. Also have just about every receipt for parts and rebuilds of engine, trans.
    Price $30,000
    Edited once, last by KCode66_old (October 28, 2008 at 6:24 AM).
  • Very nice looking Kar Chuck. You might want to note that the carb is not truly the "correct" carb as it is a Hipo clone. This is based on the fact that the cast in choke lever stop is not present on the carb body and the air tube for the automatic choke in the carb top should not be there.
  • Thanks Fred, I just went back thru my receipts from 1998 and you are correct, I sent Pony the Autolite carb I found in the trunk and they said it wasn't original to the car. So I could either rebuild that carb or swap for a 4100 clone wanna be and that's what I did.
    Thanks for the pointing that out. I corrected the ad.
    Chuck
    Edited once, last by KCode66_old (June 25, 2007 at 7:06 AM).
