Nice example of original rear spring markings
  • Quote from 6hypo5conv
    This catalized urithane that bigal mentions kind of concerns me....I guess I'll know when the lacquer thinner won't remove it???
    Yes, you'll know pretty quick! You could always dab some paint remover on the stripes, but will have to be careful not to get it on anything else.
  • Quote
    ..........I wonder why my restorer elected to do the markings like he did?
    Its common to find restorers using what they have seen or are comfortable. Have a guy use to 69-70's he will always lean towards stripes.
    We start seeing stripes at San Jose in the mid year of 65 production (intermixed with dots) and move towards more to all stripes as we get into 66 production there from what I see
  • Quote from J_Speegle
    Jeff - my 9/65 scheduled build '66 SJ car has the dots.
    The Ford Motor Co. product engineering drawing indicate paint stripes.
  • Quote from kar-nut
    Yes they do and thanks for reminding us again of another place where Ford documentation does not align with the facts and evidence in the real world ;) or maybe the engineering drawings are from the period after the dots.
    Its great when multiple things (documents and original car findings) do all align. Makes everything a little easier
    Edited once, last by J_Speegle (December 21, 2009 at 7:04 PM).
  • The Ford documentation confirms what you & others have seen that paint stripes do exist. It would seem reasonable that both methods of applying the part ID color code are correct & not only dots.
    Many car enthusiasts seek documentation to add credibility to confirm what is presented as original. I think that sharing the Ford information helps to full fill that need.
    It's always helpful to have the documentation and greatly appreciated when the information is made available to help these discussions.
    Edited once, last by Round2k (December 29, 2009 at 10:44 PM).
  • Just got done cleaning my august 65 build SJ k coupe rear leaf springs and found two red dots on the last leaf. both left and right are the same
    Edited 2 times, last by earlyk_old (January 15, 2010 at 9:03 AM).
  • The date codes on these springs are quite close to the
    scheduled build date. Jan 5th and Jan. 16 or 18.
    Which is right and which is left. I have noticed that
    on 65 Shelbys the oldest spring (if different between the two)
    are located on the left side. Several 65 Shelbys built in the
    end of March at San Jose have 16 or 18 5 E on the left side and
    75 5 E on the right side. Jan. 16 or 18 and March 16 respectively.
  • Quote from earlyk
    That is the correct ID markings for a coupe with special handling package.
  • That would be correct then for the GT's its a K GT with the Special handling package... I will send some photo's of the paint stamp markings on the disc brake calipers as well, that I have found
  • I was reading this topic and see where the spring with oldest date question wasn't answered so I wanted to ask it again.Is this referenced as the drivers side being the left side and passenger the right side where the oldest spring is put?
  • Quote from lscman
    I can't imagine that being anything other than a coincidence, but certainly is something worth checking into. I can't speak for BoS, but when I refer to the 'left' side of the car, it is the driver side (U.S.)
  • That's what I do too, left is driver side.
    Strange that several Shelby 65's have these
    big difference in dates 16 and 18 on drivers side
    and 75 on passenger side.
    Charles, after you convinced me with your pictures
    that te green and yellow dots should be sprayed on
    I cleaned mine up and bought spray paint instead.
  • When you order parts Ford has always made the left side drivers side.Now what date number goes where as the last original Dearborn 65 GT I seen the oldest was on the passenger side?
  • Was looking through some old posts and just wanted to add that the RH leaf spring on the K convertible was actually the later dated one (18th day). For whatever reason, I had marked 'RH' and 'LH' on a piece of tape when I removed them from the car.
  • Thanks for your input as I remember the cars I've restored the leaf spring with the oldest date went on the passenger side.The early 65 Hipo Mustang I bought awhile back when I took the springs off to restore them the oldest spring was on the passenger side also like the others so I put it back that way.
