Engine compartment black paint
  • Talk about reaching for the moon! Has anyone found the correct Ford paint for the engine compartment or the correct color for any of the black components used in the engine c ompartment - fan, shivs,brackets ect? I know we all have out favorite mixture but do we have a clue as to what Ford used for this? I feel that everything I have used or most of what has been seen leaves something to be desired. Ford obviously had some spec for this paint - is anyone able to come up with that mix? What are your thoughts?
  • I can't answer intelligently, but I use Plasticote Universal Black for these items, and have been very satisfied with the sheen and durability so far. I know that doesn't answer your question, but maybe you haven't tried this paint yet?
  • After stripping and prepping my engine compartment, I sprayed it with Engine Compartment Black from The Eastwood Company. It thinned easily and went on great. Over 15 years later it still looks new. The sheen is perfect and if you like I can send you photos.
    Cheers.
  • I think there are two different areas referenced here. One is the compartment, and one is the black accessory pieces and such. I was speaking earlier of the brackets, pulleys and fan.
  • Quote
    ...... I know we all have out favorite mixture but do we have a clue as to what Ford used for this? ........
    Please remember that many of these pieces were not painted by Ford or if painted by Ford, painted at dozens of distant locations using different products and mixtures. Also the amount of gloss was also effected by the painting process (sprayed or dipped) so most of the bolt on items should look different from the engine compartment walls and each other.
    One product does not fit all IMHO
  • I am in total agreement with Jeff on the different "shades" of black on engine components. I feel that most being done by restorers have too little gloss, but have never come up with a paint that I felt duplicated ANY of the various brakets and add ons to the engine let alone a specific item. I have a burning interest in what Ford used/specified for the engine compartment during the time the "K" kars were made and I am sure they had a specific color that was used when this area was sprayed, but have never, ever seen that spec in print or been able to duplicate the sheen and texture. Anybody hooked up with Ford on a solid enough basis to find out what was used and where it was sourced?
  • My body man is supposed to be putting together a black "color wheel" for me with varying shades of black. I can then use this to compare original parts as they are cleaned to try and get an idea of what would be a close replication. As Jeff says, nothing is really definite, but we do see patterns after observing original cars. For instance, we know the engine bay braces on '65 convertibles were painted with black lacquer paint which isn't very resilient! Something else to consider is that Ford rarely, if ever, used primer on parts. Instead they were usually zinc plated or left bare metal before paint. This could also have an effect on the final surface texture and gloss of painted parts.
  • We saw a great example of an unrestored 65 GT last weekend at Mustang's Plus and the level of gloss was generally higher than that of most restorations. It also had a lot more runs and imperfections than most restorers would want to have in their paint jobs.
  • Most bolt on painted black components were E-Coated Ford paint spec. ESE-M2P10-A. Some pulleys call for a black rubber resin coating ESE-M99J252-A, no paint/coating in the belt grooves.
  • try Krylon #1613 satin black for the eng bay. It is spot on and very easy to touch up after you bang that eng into it. Runs etc can be easily applied. I like the do it yourself style and am always satisfied with coverage and sheen.
    pulleys and such I try to use Plasticoat semi-gloss and brackets and braces that were dipped originally a quality gloss black applied heavy looks outstanding.
    This has worked for me. Goldy
  • Kar nut, is there a way to convert this spec to an available paint. Can an ordinary person get any of this paint somewhere? Suppose I were to supply ford Motor company with a widget for use as an engine add on part and had to provide this paint on the part I made? How would I source the paint for the part so I could sell it to Ford? Also, obviously the same question about sourcing paint still go for the paint used in the engine compartment - is there a spec available for this as well? I ask these questions because of being unhappy with the black I have had to use up until now - it has always left something to be desired. Nothing I see looks exactly as Ford did it in the day.
  • I don't know if that type of paint is available over the counter. To achieve the OE look you will have to find a company in your area that can electrocoat/E-Coat automotive parts. Ford & all the others still have parts E-Coated for corrosion protection. Google the spec, & E-Coat for more information.
    Automotive finishing materials have changed over the years due to environmental & health concerns. I believe e-coat paint is now a water borne material.
  • During the time frame when our K cars were built did Ford use the E-coat for parts? Also, the engine compartment was sprayed black at the plant, correct? Is there a spec that Ford used for this paint? Can a person find that specification? I will Google the accessory E=coat spec and see what comes up.
  • The E-Coat process has been around for many years.
    I don't know what paint was used for the engine compartment. I suggest having an original car scanned at your local automotive paint store for the correct shade of black.
  • OK, the google search worked. However I do not know a bit more than before. No details, just the fact that the ESE-M2P10-A is applied .512 Mils thick and has a salt apray rating of 168 hours. It also was called engine compartment paint, and appears to be one of the lower grades of engine compartment paint as well as a spec for coating brackets. So now I am confused, was this an E-coat or just ordinary paint. Perhaps others will also Google the spec and give us their take on the results they read. The second spec that Kar Nut mentions is called resin based, either hardened by air or baked. Help!
  • I have Access to Ecoat. aslong as the Manufacturing Facility Stays in Business, Actually its pretty cheap, you can get bulk parts ecoated aslong as their clean of rust for about 150 bucks, it doesn't matter how many pounds you bring, this includes top frames, pully's bumper brackets etc. I gave some little items to ppg and they confirmed they were ecoat. just reciently I got an nos oil filler cap, and its ecoat. Convertible top Frames work great durring ecoating. Somehow their bushings survive 400 degreas. if you run a seat track through the coat process with out taking the track apart the bushing melt. so Top Frames must have been assembled before plating as the bushings survive. I have been ecoating stuff for along time. On the engine compartment like some of the underside of mustangs it could of been hot wax. as you can sometimes notice on undrestored cars you can scrape the bottom of the floor pan with your finger and its somewhat not durabale or if you remove the front sway bar and the original paint is still their its easy to scrap. Ford has used hot wax since the model t
  • Well, we are no further down the road to an finding a black paint that is the same sheen as that which Ford used in the mid-sixties. So a little different approach may uncover something. Have you found or know of a paint that LOOKS as if Ford applied it when the car was built? I still think that most of the cars being restored today have an engine compartment which lacks the original sheen and what we are using today has an "eggshell" look which is very different than the original. I looked at an original just today, as Kar Nut suggested and upon shining it up with just a clean rag it certainly looked to have far more shine than is commonly thought correct now. Perhaps I made it shine by cleaning, not sure about that. The car had been sitting for years and there was no way I could get the color "shot" by a paint sales person, but if anyone reading this has an unrestored engine compartment and has the time and inclination to drive by an automoible paint store for a "scan" of the color it seems a lot of us would be interested in the results. Anybody up for that? Thanks to those of you who have posted comments on this subject.
  • I think we're probably splitting hairs here as the exact specification could not have been applied perfectly on every car. Based on original cars I've seen, the gloss of the engine bay varied throughout a production year and assembly plant. Some more shiny than others. There could be many factors that have an effect on the final coating appearance, such as:
    -The amount of paint applied (wet or dry coat)
    -Consistency of materials used from the supplier
    -The catalyst/reducer mixture at the time the paint was sprayed
    -The temperature at which the paint was applied
    -Contaminants in the air line (i.e. water)
    -Spray gun condition
    While there are a lot of things we can get a pretty good handle on, I'd say engine bay paint is one of those things that we just have to say "close enough" and move on.
    :):D
