Could I get a few of you guys to go to this link and look up October of 1965 calender and tell me in your opinions what is considered the 3rd week of Oct. This relates to the code on my 715 carb, built 3rd week of Oct or 5O3, thus my engine assembly date would have to be 3rd or 4th or 5th week of Oct. You will have to look at the calender to see what I mean.
What is considered the 3rd week of Oct 1965
Hi,
Don't understand your comment on the assembly
date of the engine. The engine was assembled
shipped to and installed at San Jose with an Autolite
carb and then Shelby replaced them with a Holley for the
4-speed cars (also automatics through car #799) at his L.A.
plant. This means that the date code on a Holley can be
whatever date earlier than the car was reworked at Shelby.
For example, 6S923 was produced at Shelby in Feb 1966,
engine assembly date is Jan 6, 1966 but the original Holley
carb is dated 581, i.e. first week of Aug 1965.
Ok, here is what I know. My car was invoiced out of Shelby on 12/28/1965. 715 carb is 5O3 third week of Oct'65. Mustang production guide and secret decoder disk agrees on 11/10/65 as very close assembly line production date. After comparing lots of data I believe my engine date code should be about 5K7 with an engine assembly date of 5K11. I have noted 12 C5AE blocks or more.4-7 days after casting to assembly is common and I have see 30-45 days too. Then shipped to San Jose by rail.
What do you see wrong with this time line? All that is missing on my car is the block. All date coded original rotating assembly and externals I have. I.E. fan is a J5-balancer J5.
The problem I have is the reference in your poll email between
the assembly date of the engine and the Holley carb date.
"This relates to the code on my 715 carb, built 3rd week of Oct or 5O3, thus my engine assembly date would have to be 3rd or 4th or 5th week of Oct."
To my knowledge, there is no correlation between the two.
Can your carb date be original to your car, absolutely.
Bo,
I knew Shelby put the 715 carb on it but I just wasn't thinking. Now I am straight on the point.
What do you think of the rest of my time line.
Marv and I were wanting to do some research on what the average amount of time it took for the train ride for the engine from Cleveland factory assembly point (early '66 Windsor hadn't started yet) to San Jose.
My car was built about 5L10 probably arrived at Shelby 5-10 days later. Was not shipped out of Shelby until 12/28/65
Hi,
My original engine block cast date is 5D23 and my
engine assembly date is 5E3, i.e. 10 days later.
Car arrived at Shelby on 5/13 another 10 days later
than the engine assembly date. Car is 5S275.
As you can see a very tight time line. Engine shipped from
Cleveland to San Jose and put in the car and shipped from San
Jose to L.A. All in just 10 days. Maybe they flew the
engines to San Jose. My 513 carb is not the original to my car.
As regards your time line, I think you have done a terrific
job to identify the most probable block cast date and assembly
date. However, I believe it could even be a bit closer to the
5L10 date than almost a month earlier 5K11.
Are we sure that the engines were assembled at the Cleveland
plant or were the blocks just casted there? Personally, I haven't seen any documents saying neither nor.
It's a very interesting subject and I am as crazy as you are
on date codes. Have created a spread sheet with all dates
that relates to my car and it's various parts, sheet metal and
others.
Good luck with your continued research.
Quote from BoS
others.
Take comfort in knowing you are not alone in your insanity! My engine assembly date was 12/17/64 with a scheduled build date of 12/30/64.
Some more info on 6S923. Scheduled production at San Jose
was around 12A, i.e. Jan.12, 1966 and engine assembly date
Jan.6. 1966. Only six days. Block cast date was Dec. 4, 1965.
Bo,
Thanks for sharing your information on an ariginal car. My buddy has 6S749 and it too has original block date 5M1. His time line is very similar to yours. I did notice when he had his engine out for rebuild that he has the only K vin code block I have actually seen seen other than in pictures. I have found the vin stamped blocks to be rarer than the non-vin blocks.I have had a 1/2 dozen various code 289 blocks and none of them were vin stamped.
Wish I knew more about what blocks got stamped and why so many did not. The block vin numbers were stamped after the engine assembly date stamp was put on block, presumably just before it was lowered in the car. Any data on what factory plants were most consistent on doing the block vin stampings?
One of the things a lot of people aren't aware of is that the vin was assigned at the begining of the assembly line and stamped at some mid point in production so they came off the end of the assembly line rather random as some cars were delayed coming down the line for a particular reason or snag. Many guys thought they got stamped at end of assembly line in perfect sequence.
My experience, which isn't that great on ownership of
HiPo engines, is the opposite to yours. My 65 Shelby %275 has the
original stamped block, the 66 Shelby #923 that I used to co-own has
original stamped block, the engine in my 67 Shelby (not-original)
has a stamped block (August 64) and a 67 HiPo engine I used to own had a stamped block as well. The 65 and 66 Shelbys were very visable
without any cleaning necessary while the other two took some real
work to make visable. Those two were found in Sweden and had been
used in winter times which made the surface rust quite deep.
In fact, many years ago here in Texas I was looking at a 65 GT HiPo
coupe and couldn't find the vin on the block and passed on the car
for $9500. The guy that bought it took off the paint and the vin was there.
Do we mean Cleveland or Windsor?
As for San Jose the parts (before they went to the plant) would go through Richmond, Ca where they were often checked for damage (and routed. Damaged panels and such were often then rerouted to the service replacement supply, rather than the plant. Know a number of guys that worked and ran the distribution site
Quote
Maybe they flew the engines to San Jose...
Complete V-8 engines were shipped from the Cleveland plant by rail to the assembly plants. This was the most efficient way to move the many hundreds of thousands of engines needed to fill the needs of all the Ford carlines that used the venerable 289's. Moving such tonnage by air would not be cost effective or necessary. The finished engines were packed in containers that could hold many engines a piece. These containers were loaded onto railcars that could hold multiple containers. With an expedited schedule, it's possible to run a freight train from Ohio to the West coast in less than a week's time. The Ford assembly plants have rail connections that go from the mainline to the plant, so that railcars could be unloaded directly into the plant for maximum efficiency.
Quote from BoSAre we sure that the engines were assembled at the Cleveland
Engines were manufactured and test run at Ford's Cleveland Foundry and Engine Plant. This has been confirmed by numerous independent researchers and Ford historians. I personally spoke to a retired Ford employee who was in charge of the dyno testing laboratory at Cleveland. He confirmed that 289 engines were assembled and tested before they left the Cleveland plant. He also confirmed that the engines were packed into heavy duty containers, and were shipped by rail to the appropriate Ford assembly plants that used them. Engines were randomly taken from the Cleveland loading docks and brought to the dyno room for quality assurance testing. If an engine failed on the dyno, it was stripped down and analyzed for defects. It was his responsibilty to oversee the tests and maintain documentation of the test results.
Quote from J_Speegle
In general, most engine information on this site pertains to Cleveland, since Windsor did not produce the HiPo 289's...
Quote from J_SpeegleDamaged panels and such were often then rerouted to the service replacement supply, rather than the plant. Know a number of guys that worked and ran the distribution site.
That's correct. Many body shops obtained these pieces when ordering repair parts, and they often had to deal with service parts with imperfections. Back in the Sixties, I ordered a lot of body trim parts for my '64 Fairlane Sports Coupe, including the stainless trim mouldings that ran the length of the body. Even though they were new parts in factory wrappers, a few were less than perfect...
Quote from BoS
The scheduled build date is often out of sync with the actual assembly date by many days-especially on the K code cars. My car was ordered in late December of 1964. It has a scheduled build date of February 15th, 1965. The engine was actually assembled and stamped on the same date! The car wasn't invoiced and delivered by the dealer until March 31st, 1965.
Gene,
The engines were likely sorted according to engine code. In other words a ccontainer would most likely be all C code or all A code or all K code etc. The engines that were packed into
the container first at the engine assembly plant were the last ones out of the container at the auto assembly plant-perhaps-unless the container had an access door on each side.
Lots of variables make this date code thing very interesting to me.
Saw a 5K13 block today with a 5K14 assembly stamp.
One last point. I have seen pictures of bock vins stamped very neatly and evenly spaced, probably machine stamped, Then I saw one block (original) that was stamped very messy- obviously hand stamped as the characters were slanted etc.-Ray
Quote from SixT5HiPo
I have to agree with Gene. There is no way that the auto industry would ever consider shipping heavy auto parts like that by plane. There are dedicated freight trains that have priority as a fast hot
shots to get those parts to the assembly plants. I know, cause I'm an engineer for a freight railroad and I used to bring a train from New York State to the Metuchen assembly plant. This train originated from Toledo, Ohio. It was a two day trip. We would be the first train out of the yard that day because we were hot. Even the rail gangs had to clear up just so we would get through. At times I would work the yard in Metuchen and switch out the plant. There were times that I had to re-spot the freight cars back in the plant because certain cars had there own spots at the rail dock. I took the oppurtunity to look in the cars to find out that it was packed with engines in special metal cages from floor to celling. Some had fenders, engine hoods, axles, etc. We at times had to place a shutdown car in as quick as posible, because, if it was late the plant would shut down until that one car arrived. The rail industry has a fine line to keep the network going and one derailment causes a ripple effect. The railroad is the most efficient way to transport heavy bulk cargo. At the time I was working there, Ford was making the little Ranger trucks. There are trains that run from North Jersey to LA. in 72 hours.
Dave V.
Talk about a "Just In-Time Supply Chain already
in 1965. Shelby 5S275's engine block casted 4/23,
engine assembled in Cleveland on 5/3, sent to San Jose
to be meeting up with the rest of the car, driven off the line,
shipped to L.A. and arrive there at 5/13. Could be like this:
5/3- engine ready
5/4- shipped by train to San Jose
5/7 or 8- arriving at San Jose
5/10- car complete and ready to go.
5/11- shipped to L.A.
5/13- arrive at L.A.
Very tight but possible. As said above, I am very impressed by their Supply Chain.
Dave,
Glad you got in on this discussion. I was hopeful we had railroad guy that could talk the talk about not only the railroad but also the assembly plants.
Ray
Quote
The engines were likely sorted according to engine code. In other words a container would most likely be all C code or all A code or all K code etc.
That would make sense, but I've never confirmed this...
Quote from poboy427Dave,
Ray
Dave V. has provided us with some interesting details on how the railroad served Ford's Metuchen Plant before it was closed forever. His firsthand experience working on the railroad that served the Metuchen assembly plant confirmed and expanded the information already gathered from other sources regarding the way production material was delivered to the plant. Most of these methods are still in use today at Ford's operational assembly plants, just as they were back when the original Mustangs were being built.
Because of the amount of raw materials and parts needed to mass produce automobiles, railroads provide the most efficient way to move most of the material needed to supply the factories, foundries, and assembly plants. As a railroader, Dave performed an important role in the routine process of bringing carloads of assembly parts, including engines, to Ford's Metuchen Assembly Plant day after day. After all the parts are assembled, and the vehicles are completed, they are loaded into special railcars called auto racks. They measure about 90 feet in length and usually have three levels that can hold a lot of cars. The autoracks are made up into long trains that move hundreds and hundreds of cars at a time to distribution centers all around America. The cars are driven off the racks and loaded onto trailer trucks for final delivery to the dealers.
All of this has to work like clockwork every day for the auto industry to maintain peak efficiency. As Dave mentioned, sometimes just one railcar loaded with critical parts can make the difference between a plant working on schedule, or one that is forced to shutdown because all the parts are not available. It's amazing to realize how complex this system is!
