4 SPEED SHIFTER CABLE
  • i have 68 4 speed shifter handle that i would like to have re-chromed. how do you remove the reverse lockout cable from inside the shifter ,i removed the reverse pull knob but cant get the cable out, can i leave it in and still have it chromed.
  • The bad news is - you can't. The good news is - there is a company that will do it for a nominal fee of course. I can't remember their name but I think they were located on the east coast.
  • The fellow on the east coast is Bill Heeley. He reconditions the handles and the shifters. Nice guy and easy to deal with:
    3621 Mt. Olney Lane
    Olney, MD 20832
    (301) 774-6710
  • Hi,
    Sent two shifters to Bill Heeley and got them back a few days
    ago. Excellent work and a nice guy to do business with.
    Have a question for you. He puts on a rubber or plastic bushing
    over and under the reverse sleeve and I wonder if these shifters
    came with those originally. I know that Ford used them on
    NOS replacement shifters because I bought one in a box many years ago
    and it had those bushings. However, I have never seen them
    on an original. Could it be that they just have worn out over the
    years. Thanks for your help.
  • Yes,to all your questions. If you send him the
    boot he will put it on for you as well.
    He did two of my shifters a few weeks ago and I sent him two
    NOS boots and he put them on. Excellent work!!
  • Quote from chucks302
    Thanks guys, i will give him a call .
    I got the cable out by soaking the handle in penetrating oil, then cut a metal coat hangar and used it to push out the retainer washer from the top slot hole in the handle out the bottom ,then remove the cable and washer together,
  • Quote from toolbox
    I don't mean to hijack, but how do you get the "T" trigger out of a '65 style handle in order to change the shifter boot?
    There is a small drift pin that retains the cable to the T trigger, you remove that pin/the shifter ball and lock nut/ then slide your new boot over the handle,
