heater core removing
  • I need some help.the manual that i have ,shows.1,2,3 and its out.whats is the best way to remove the heater core? 1965 2&2 h.p. there are 11 spring clips around the box,how do you remove the upper one's and the right side clips?i can't really see them,let alone try to remove them.thanks you for any help. jim
  • Quote from BoS
    Bad news, but I think you need to remove the
    complete heater box.
    No truer words spoken. You can remove the heater cover while installed but getting it back on is next to impossible.
    The best way is to cut the hoses in the engine compartment and make a heater elimination loop, undo the four nuts around the blower then do the inside stuff.
    There are three control cables that need to slide off the control arms, one on the defroster deflector in the middle and the two on the box itself. There is one 14-14 x 1 1/2 hex head sheet metal type screw in the upper right hand side of the box that attaches it to the dash. It's to the right of the glove box liner. Be careful in removal as the defroster deflector (aka plenum) is made of cardboard.
    I assume that the core leaks. I recomend as long as you are there to replace the hoses and get a gasket set to rebuild the insides. Forty two plus years takes its toll.
  • Once you have everything disconnected it will have to come back to clear the studs on the blower motor then down. The large round foam gasket that connects the cowl to the top right corner of the box may stick if it's really old.
  • can anyone tell me when dropping the heater housing,it looks like the fan motor goes with it,how hard is it going to be ,when installing the blower motor,and trying to align the 4 studs?
  • I just did this on my 65 Shelby. Put the original
    date coded back into the car. It's a very straight
    forward job if you have removed the passenger side front seat.
    As said in an earlier post, be very careful with the
    cardboard plenum. It must be mounted on the heater unit and
    installed as a unit.
    Good luck,
  • The heater motor and squirriel cage are mounted to the heater casing via four nuts.Once the casing is out of the car on a bench,seperate the case ,remove the four nuts that hold the motor to the case and it will lift out . No real problem once you get the case on the bench. If you have a center consol it will make it a little harder getting to th plenum. the motor will be reinsalled as a unit within the case, the four studs should line up with no problem. Another pair of hands on the outside to guide them will help. Good luck...
    Joe A...
  • THE HEATER UNIT IS OUT,NO PROBLEM GETTING IT OUT ,(AFTER EVERY ONE'S HELP).THE HEATER HOSE'S THAT ARE ATTACH TO THE HEATER CORE,I CUT THEM OFF, AND USE A CORK TO PLUG THEM,AND REMOVED IT,WORK GOOD,NO ANTI/FREEZE SPILLS,IN SIDE THE CAR THAT WAY.I DID ORDER THE GASKET KIT TO RE-SEAL THE HEATER BOX. THANKS JIM HAPPY NEW YEAR..
  • my son and i replaced his heater core last night.
    we had a good time and learned a lot.
    this thread was quite helpful.
    a couple of comments tho:
    all the rubber seals were either gone
    or crumbled to dust!!
    be sure to let the trim adhesive get tacky
    on both surfaces before you apply the rubber pieces.
    trial clamp everything together to ensure good fit
    before installing the little metal clips
    we had to adjust the largest vent door
    as we could see where it had rubbed a dime sized
    hole in the fiberglass; bet this drove s.o. crazy!
    REMEMBER to put in the large fresh air vent rubber!!
    we forgot and had to remove the unit from the firewall!!
    as the fan motor worked fine, we did not change
    the seals between it and the 'squirrel' cage
    and.....it seems like the casting nuts are pretty
    flimsy to be holding the heater unit up to the firewall?
    but......i guess between them and the core hoses
    and the other hook ups, it is secure enough!
    now to check the motor switch etc.
    it is nice to be helping my son do his C code stang
    as it will really help when i go to do the K code!!
    thanks
    iowa
  • I just rebuilt a heater core in a 67 vert last week. It's a pretty cool car. It's a 67 390/4speed car, brittany blue and white top. The heater box needed the whole rebuild kit put in it and it's working great now. I used some fiberglass to patch up one area that was broke an you can't even tell after I painted it.
