I have taken my rally pac off the car and need to clean it up. The chrome on the eyelids is somewhat corroded. Do they make new ones or should I get this re-chromed?
Rally pac restoration?
Not sure if those can be bought separately. Check the parts catalogs.
Otherwise, you can get them re-chromed.
I hope you're smarter than me after you removed your Rally-Pac. I sent it out for restoration and several days later tried to start the car. It would start then immediately shut down. Had to connect the ignition wire that goes to the tach with the resistor wire from the coil.Found my answer to the issue on some Mustang forum.
Wayne
If the car was running it might be an issue lol I hope to be able to restore it myself.
I just sent my ralley pack out to the tachman at H & H Auto electrical.
http://www.tachman.com/rally.htm
I like his motto " fix it up so you can rev it up ! "
My tach works but the clock doesn't. The housing finish is fine on mine but it to has some pitting on the chrome. Needles are dull as well.
Quote from GregM
Hey Gregg let us know how it came out, I am looking for a place to send mine.
Mike
I can recommend Phillip Severence. He restored my tach and does clocks too. Very good service.
The Tachman restored my Rally Pac going on five years ago now. Fixed the tach which worked intermittently and did the quartz conversion on the clock, as well as doing the cosmetics. Great job, no functional issues with it since it was done and still looks great. No problem on my end recommending him.
Jack
