Correct Colour For Front Coil Springs
  • Looking through Photos i see Coil Springs are Painted Satin Black or Left Natual , did this Vary from Plant too Plant , my car is August 65 Jan Jose
    What is the most Common Colour Finesh.
    Thanks Shane
  • For San Jose I would rather see a dark heat treated finish,
    Years ago we were interviewing one of the guys that laid out the plant (drawing the layout, out for us) and he drew a rectangle on the page and stated " theirs were the phosphated front coil springs were kept"
    Of course the next question was "why did you call them - phospated" since the common thought of the time was that they were painted. It was odd that of all the details he remember - he recalled that one. But that is what interviews with these people are like. A little detail here another one there,
    Assume that they were not phosphated just that they looked that way. And the dark heat treated finish can look very much like IMHO the dark magnesium phosphate
  • Quote from k code 65
    Great story , thanks for input , i was thinking of Painting the Cast iron look as the Rear Springs will be also.
    thanks, shane
    Painting front coil springs with the "cast blast" type paint would be way too light. We're talking a very dark gray here. Would recommend to just go with black for now.
  • Quote from round2K
    The manganese phosphate process yields a pretty dark finish, almost jet black when quenched in oil. Did Ford ever use it?
    Yep, manganese phosphate and zinc phosphate were generally interchangeable when it came to fasteners. The way you can tell if a part was manganese phosphate is to touch an original area with some muriatic acid. If the acid removes the finish, it was manganese, if not, it was zinc phosphate.
  • Quote from CharlesTurner
    Just be careful when handling muriatic acid (aka hydrochloric acid). The fumes are extremely potent, and a chemical respirator should be used to prevent damage to the lungs from the vapors. It will also cause burns to the skin upon contact.
  • Quote from J_Speegle
    Isn't muriatic acid "pool acid"?
    Use to use that in a plastic garage can to strip and derust parts in the "old days"
    Yes, it sure is. It is commonly used in swimming pools to adjust the water ph downward if necessary. It is a very powerful chemical, and a little goes a long way. It can also be used as a serious ceramic tile cleaner, and is used in a diluted form to "super clean" tiled swimming pool surfaces. It works very fast and aggressively, and has to be "neutralized" by rinsing quickly, or it will begin to dissolve the tile grouting.
