suspension and steering colors
  • Car is coming along very well,but need info on colors for rear springs,steering linkage and not sure about control arms. case and black tips or what.thank you,JR.. build date,8-20-64.san jose.
  • Items such as steering arms and linkage are a natural heat treated look (very dark steel) Tie rods also have brighter machined surfaces you will need to reproduce.
    This would include, center link, pittman arm, idler arm and mounting bracket, tie rod ends and adjusting link
    Strut rods as well as leaves of the rear springs (not eh clamps) are also dark heat treated.
    Front upper and lower A arms are natural stamped steel with plated boot retainers and the inner attachment points were dipped in semi-gloss black paint (may have caused runs or filled the lower jack taps) to approx 2/3rd the total length
    Rear leaf spring clamps, strut rod stops and rear spring plates are all natural bare steel (oiled) so the metal looks like new bare steel with the metal where the bends were made slightly brighter/smoother from the forming
    Spindles often appear to be coated or painted from the oil quenching process. In general that are slightly IMHO darker than bare steel but not as dark as the hardened steering components
    For Concours classes you can try and paint these items or use a mix of paint and coatings to reproduce the look of original parts,
    Hope this helps
  • Thanks for answering my questions, the info was very helpful. Can't find all the answers in books. It's good to be able to communicate with people who know!
    JR
  • I'm helping out a friend on a 66 Shelby (March 66 Ford build) and would like to know what the finish is on the Pitman arm and idler arm. They have been chemically stripped and are marked XRR-25479 and XRR-25490 with a faint Ford oval logo. I also have a December build Shelby stored along side the house that needs the same info (although that may be worked on next year).
    Also, what is the recomended replacement bushing for the Idler arm?
  • Jim,
    I'll let others comment on the finish, as for the other stuff....
    My 66 GT350, 6S1757, is also a (late) March build. If the logo is a round "Ford" these may be replacements offered by Branda (and probably others) since the mid-80's, don't know if that is a concern. My original idler and pitman arms have rectangular FoMoCo logos. The location of the part number and logo is also different on the replacements. On my original idler arm the part number is on the bottom while the logo is on the top side, both at the front. I've seen oval FoMoCo logos on original 65 GT350 idler arms but not "Ford".
    The original bushing is the same for the standard Mustang with (oddly) power steering, C3DZ-3356-A. If these are drivers I would recommend roller bearing kits otherwise aftermarket (Moog, etc.)should be fine since NOS are tough to find.
  • Now you got me concerned. It is my understanding that the car has been in their family for about 35 years. Here's a more detailed description of the markings of the two items.
    Pitman arm: top near hole for center link "K6": bottom from center link hole "KRR- (space) 25479, logo (something with four script bumps in an oval), (the rest is all caps but 90 deg ccw), NVD, something (a casting flaw?), B 1 B.
    Idler arm: top near bracket "M", about halfway up the shaft a small "A": bottom from post for center link, "XRR-25490, (dash) logo (something "OR" ? something), (dash) A 1 A (dash) "1" (90 deg ccw), NVD (upsidedown).
  • In my humble opinion, these two are later replacements arms
    as the NVD is present on both. The NVD stands for a specific
    casting process (Nickel Vapor Deposition) and must be shown by some Government rules.
    Some original arms have a FoMoCo within an oval and others
    within a block and all repo's I have seen has Ford within an oval.
    Original FoMoCo markings are on top when mounted and fairly close
    to the front while the repo's Ford is at te bottom when mounted
    and close to the middle.
  • Jim,
    I agree with Bo. I have two original idler arms, the one from my car and one I bought as a spare years ago from a 66 GT350 in the early 300's. Both are identical with a block FoMoCo logo on the top front (as mounted) and the XRR part number on the bottom front. I also have a replacement purchased from Branda in the 90's that I'm using on the car with a roller bearing kit at the moment. It is like the arm you describe.
    One thing I'm not clear on is if the replacement arms with the oval Ford logo are Ford service replacements or repops.
  • Bo and Dave,
    Thanks for the input. Let me add something to the mix. I just got off the phone with the owner about the two arms. He said that the car has been in the family since late 1968 and nothing was done to the car since then. When the restoration process started a few years back, he did find out that the car had been in a wreck, "sandwiched" using his body man's words, so it possible that those parts (and others) were replaced prior to 1968. In other words, the NVD processed arms date from 1968. Is it possible these NVD parts were used on 1968 and later Shelbys?
    I still need a couple of bits of info. What is the finish? Is the Ford power steering bushing (C3DZ-3356-A or aftermarket) a valid replacement for this idler type arm?
    Currently the car is a shell waiting for paint.
    Edited once, last by jwc66k (July 8, 2010 at 11:33 AM).
  • i'm not quite sure how one preps
    the metal parts before this phospahte dipping?
    do you just take the piece all apart
    so that the inside of the part is dipped also?
    thanks
    iowa
  • I use several different methods to "protect" areas I don't want to be bead blasted: masking tape or duct tape; RTV cement; a rubber grommet. Glass beads do not remove soft materials easy so that's the trick.
