• I've been told that correct date codes would be anything 3 months prior to your build date of your car..And then someone told me that more times than he can count, 6-12 months and even earlier parts, were used on Fords..?? Any truth to this at all??
  • I don't think that logic would apply to 65-66 Mustangs since they were stamping and assembling as fast as they could. For these years I think the 3 months prior is a good rule of thumb. How about it Charles, you've seen a lot of original cars, how do the sheet metal date codes run?
  • Yes, I agree with Charles. My 65 GT350 was
    put together in San Jose' around 5/7/65
    and steering box is dated 5D30, heater box
    Y5DD and engine assembled on 5E3.
    Those part are most likely original to the car.
  • Quote from garymcgowan
    Is it possible to have an Assembly Date of Mar. 2, 1966 but have a Mar. 8, 1966 date on the steering box?
    Sure...assuming your "assembly date" is actually the scheduled build date stamped on your Warranty Data Plate.
    Is it possible to have an Assembly Date of Mar. 2, 1966 but have a Mar. 8, 1966 date on the steering box? The steering box looks original but I don't know.
    One important thing you need to realize is that the DATE code on your door data plate is actually the day the car was "scheduled" to be built and usually not the actual day it was made. When the order came in from a dealer, the dataplate VIN and other information was assigned, including a scheduled build date. On the '67 and newer, we are lucky enough to have Marti reports to tell us what day a car was actually made. Generally, I see very few Marti reports with cars made ahead of schedule or the actual day it was scheduled.
  • i have a trunk floor date stamping of 1 20 3D and my door vin tag has date 27Q which is march 27th build date. so the trunk floor was made about 2 months before my car was put together if i understand this correctly. also my car is a factory 65 GT K that i bought from the original owner in 1974 minus the engine and trans. he blew up the engine beyond repair and kept the toploader. i had 2 other 65 GT A code cars and one thing about this car was 1 hole on the driver side in the core support for the fog light wire and the passenger side fog light wire went through the vent slots in the core support. what does the D on the 1 20 3D date stamping mean ?
    5F09K677490 !!!
    Edited once, last by stickshift (April 1, 2010 at 3:06 AM).
