HiPo parts starting sometime next week
  • FYI, I will begin to part out a 1966 K GT Coupe starting next week, approx Sept 12th. Parts will probably be available through Ebay. I will also be parting out a HiPo engine VIN stamped 5F09K679219. That engine is currently a complete long block that was a strong running engine before being pulled from the car several years ago.
    A quick list of parts that will be available:
    (I will list dates,codes, detailed info, and pictures later)
    - 1 VIN stamped block 5F09K679219
    - 1 good 289 block correct date code but no VIN stamp
    - 2 complete sets of HiPo heads (One set had new valve seats installed in 90)
    - 1 4bbl cast iron intake
    - 1 set of C7 Hipo Exhaust manifolds
    - 2 HiPo harmonic balancers both C5OE
    - 2 Motorcraft Dual-point distributors
    - 1 Hipo crank
    - 1 set of HiPo rods
    - 1 set of thick main bearing caps
    - 2 counterweights and thin chain gears
    - 1 original HiPo fan (has the weight on it)
    - 1 complete set of 65 motor mounts (all parts included, even bolts)
    - 1 HiPo alternator pulley
    - 1 HiPo H-pipe, used but excellent condition
    - 2 used GT exh trumpets
    - 1 export brace
    - 1 Rally pack 8000rpm
    - set of GT Foglights
    - 1 66 K GT Coupe body minus any HiPo parts except fast ratio steering box
    - 1 72 TopLoader wide ratio
    - 1 68 302 engine, internal condition unknown at the moment
  • Quote
    I will begin to part out a 1966 K GT Coupe starting next week... I will also be parting out a HiPo engine VIN stamped 5F09K679219. That engine is currently a complete long block that was a strong running engine before being pulled from the car several years ago.
    The question is: Can you say what is going to happen to the car(s) that the engine(s) came out of?
  • One of the engines I bought in 87 and it wasn't in a car at the time. The VIN stamped engine was from 5F09K679219. I bought the engine when it was in a 66 C coupe in 87. The owner told me that he had totaled the K GT fastback and had put the drivetrain in his wife's C coupe. I resto-moded the car and sold it around 90 in OKC. I installed a standard 289 with 4bbl and kept the HiPo. I wasn't well versed in HiPo tranny's back then and sold the car with the HiPo trans and rearend. SO, if anyone sees a white 66 C coupe with Gold Shelby stipes driving around Oklahoma, it has a HiPo trans and 3.89 9" rearend. I put HiPo badges on the car but never tried to pass it off as a K car. I only did it becuse they looked good and I did have a K engine in the car at the time. If you see the car, and it's like I sold it, you'll definitely recognize it if it's at a local show because I painted the engine compartment gloss white and ran the stripes down the firewall.
  • Let me know when your selling the main bearing caps/block and whatever else. I have always wanted to build a hi po but the parts are so hard to find. Also let me know the price your looking for.
