• Starting bid $6500, BIN $15.5k
    No bids for this E-Bay Listing: 66 K Coupe
    by seller "lew-lew39"
    car in Oklahoma
    Quote
    This is a nice Mustang Coupe that has been refinished. It is Acapulco Blue and was stripped to bare metal before painting.The previous owner represented this car to have actual miles. The Oklahoma Title shows mileage exempt. This Mustang was previous on the Drag Strip was the explanation for low miles. He owned the car the last six years and drove it about 200 miles without racing it.
    The interior is very nice with the after market GT steering wheel,and radio. The dash pad is new. It has automatic transmission that has a shift kit, and the B & M Pro Stock shifter. The Rocket Wheels have like new tires that are 215 X 60 X 15 on the front, and 295 X 50 X 15 on the rear. This is a great looking (K Code) Mustang.
    The exhaust is new. The car is clean underneath. When you peel off the undercoating the metal is shiny and original. It has low gears with a Locker rear end. The Data Plate shows, Body 65A, Color Y, Trim 22, Date 05K, DSO 61, Axle 5, Transmission 5. The engine code is C3Y. It has HP engine block with a 750 Holley Carburetor, Excell distributor. It has an electric fuel pump. The car sounds awesome.
    http://cgi.ebay.com/ebaymotors/196…1QQcmdZViewItem
    Edited 2 times, last by 66tiger (March 4, 2007 at 12:37 PM).
  • Back again... BIN $17.7k
    Different seller "transworldmotors"
    car now in St Louis, Missouri
    a few minor cosmetic changes to car
    New Listing Info:
    "This beautiful 1966 Ford Mustang K Code Car is finished in classic Acapulco Blue, with new black vinyl interior and new black carpet. The Ford recently underwent a "frame-on" restoration. Before the new paint was applied, the Mustang was stripped to bare metal. The paint on this classic Pony Car is in exceptional condition. The car also boasts new Torque Thrust Wheels with matching Cooper Cobra Tires, it has new exhaust, clean underneath with no rust, 9 inch Locker rear-end with low gears, Power Steering and Power brakes, and the high performance 289 engine. The previous owner represented the mileage as actual, though the title reads exempt. This Mustang is turnkey, and ready to enjoy. The Mustang is powered by the original, high performance 289, 271HP K code engine that has less than 500 miles since a complete rebuild. The C-4 automatic, shifts out very smoothly, and all of the fluids have been changed."
    http://cgi.ebay.com/ebaymotors/ws/…93324&rd=1&rd=1
  • Anyone else notice that the shock tower bolts are pointing into the engine bay? I wonder how much work was done previously. Also wonder why undercoating would be put directly on top of bare metal on the underside of the car.
  • Yup; small damper & small alt pulley. No original manifolds or fuel pump either. Doesn't seem like there are any original hipo motor parts visible under the hood.
