Is C3DZ-8146-D the correct part number for a 65 K code fan shroud ,
FAN SHROUD
According to the MPC that is the correct number.
Please be aware of though that the Ford replacement
use the part number but it looks completely different from
the originals.
Thanks for that info, is there repo shroud that is correct in fitting and apperance i need two of them. Chuck.Quote from BoSPlease be aware of though that the Ford replacement
the originals.
Location of part number?
And, how do the replacements look different?
Thanks!
The structure isn't as sturdy and the most obvious difference
is the lack of a rubber pad stapled on the passenger side to protect
it against the battery tray. Originals have that pad and replacements
don't.
It's hard to tell the difference without holding them side by side. The rubber pad isn't a big deal to install, uses the same style staples as the splash shields.
Thanks for all the input, bought two NOS shrouds on e-bay in unopened ford boxes they both look great to me , i will now need to install the rubber piece, Chuck.
NPD does have a "concours correct" repop fan shroud with the rubber shield, part number 8146-1B. Don't know how accurate it is since I've never seen one....
I have fan shroud rubber for sale but no staples?
