aluminum/cast iron bell housing
  • The cast iron and aluminum bellhousings have the same motor to trans dimensions. Most cast iron bellhousings use the 164 tooth flywheel rather than the 157/160 tooth for the 289 Mustang and Falcon. This will also makes the block plate different between the two flywheel sizes.
  • Never seen the cast iron ones in cars - except the COBRA scatter shield - rare and expensive.
    The cast ones were used in trucks of that era - seen a bunch in older pick ups and large Ford trucks.
    They pop up on ebay from time to time - and Fred is correct - they use the larger flywheel/clutch assembly.
  • The only advantage to the cast iron housing would be that you are less likely to strip any bolts. Make sure that you have the correct block plate.
