Engine Date Coding
  • OK, Need some help....Question for all you gurus out there.
    Got a 65 Coupe GT/K build date 01R (April 1 1965) Correct me if I am wrong....
    Engine has all the K-Kode stuff in it and never looks like it has been removed. I am concerned that the date codes on the engine are not consistent with the Warranty Plate Build Date mentioned above.
    Now Page 6&7 of the 4th Edition book states that my car should have a 6 bolt bell housing and the numbers cast into the block behind the starter should be C5AE-6015E and this is consistent with the April 01,1965 build date being after August of 1964.......
    .....but....ready, the date code above the C5AE-6015E casting is 5C12....I interpret this to say March 12th 1964, 13 months prior to the build date. March would be great if it was a 1965 March which should be Q....yes/right/maybe? ugghhhh
    So....since the C5AE-6015E casting says the motor is newer than the August 1964 equipment then it should not have a 5C12 casting unless someone flubbed the casting run and put a C for March instead of a Q that the book defines for 1965 cars. All other castings on the heads, and intake are 5C2 and 5C3 dates.......
    I thought maybe it was a warranty or replacement block done at the dealer after purchase which might make sense based on the casting and if a failure of the original engine caused a dealer replacement then an early March block etc might have been dusted off and put into the car.....no?
    Still, the C5AE-6015E casting is throwing a loop into that theory and I am thinking someone was imbibing on the job at the casting factory and accidently used a C cast for a 1965 batch of parts versus the expected Q????
    Any thoughts???
    SoCal65GT-K
  • Parts, including blocks, are not date coded like the 65 Mustangs as they were strictly by calendar year. Your block is actually March 12, 1965 and not 1964. The block that you have certainly falls within the build parameters at the time. To make it totally correct you should be checking for the VIN stamped in the block.
  • Fred,
    That is music to my ears! Like the tapping of the solid lifters coming from under the hood of my coupe!
    I have yet to find the stamping on the block. It should be passenger side and I am familiar where it should be based on history of owning other cars. The transmission is stamped correctly but I have not found the engine stamp, if it exists.
    Based on all the notes in the Mustang book I had expected that the 1965 March would have been designated by a Q versus the C but it would be a heck of a coincidence to have it set up with a March 64 block.
    Appreciate the feedback. Smiling in San Diego,
    Andy
  • The letters Q-Z were only used on the Warranty Plate Date Code as shown in the book. Casting/Stamping dates never used those letters. Rather, usually A-M leaving out the letter I. Look at the example of the Date Code on the Head on Page 21.
  • Yep,
    I for some reason kept interpreting the book to date code the parts the same way the warranty tag was.
    You guys have been very helpful.
    Although my block does not appear to be stamped with the VIN I have to assume it is correct in the fact that the block, intake, and heads have all the correct date coding, correct hipo markings on the heads, has the larger harmonic balancer, fan and shroud are still in place as well as the exhaust manifolds.
    I can't imagine this car has ever been taken apart.
    My next step is to take off the exhaust manifolds to look for the stamped VIN. If it is not there I can justify that this is just one of those engines that did not get VIN'ed.
    I bought this car on a whim from a guy who did not think it was original. Hoping that this car is all that it can be.
    How can I validate it is a true GT, etc?
    Any feedback would be welcome.
  • Quote from SoCal65K-GT
    We've gone over this GT question many times here. We know that the earliest build date for a factory GT Mustang is probably mid February of 1965. Since your car has a scheduled build date of April 1st, it could be an original GT.
    Use the site's ADVANCED SEARCH feature and type appropriate keywords to find out all the information on this site regarding GT Mustangs. Don't forget to also check the ARCHIVES box as well...
  • I read on Ebay forum that 289 blocks are identified to the particular model by the second letter in the casting code, ie C5AE-6015-E, the A represents the model. They say A is Galaxie, and that Mustang is Z. That means Mustang block should be C5ZE-6015-E??
    Yet all I read in this forum (and almost everywhere else) indicates all 289 blocks are C5AE (if cast in 1964/5)
    I am looking for an engine for my K code manufactured on 10/31/64. Can you knowlegable guys steer me in the right direction please. And if you have the right engine for sale I am in the market (also need a toploader HEH-T, HEH-S or maybe HEH-BX and a 9 inch rear)
    Andrew
  • Quote from rallyman
    The casting numbers on 289 engine blocks weren't specific to each carline that used them. Remember, besides Fairlanes and Galaxies, the 289 was used in Mercury Comets, Ford Falcons, as well as the Mustangs. There wasn't a need or purpose to have a different casting number assigned for each brand. Blocks were cast, and engines were assembled before they were shipped to assembly plants. The assembly plant is where it was determined into which car the engine was installed.
