VIN stamping
  • Hi Everyone
    Firstly great site and thankyou to all those who contribute. I've been watching and learning waiting for the day I could own my own K code. Think I've found quiet a good Kar everything seems in order except for the clone carby.
    Anyway I'm at the point where I would like people's opinions on the transmission VIN stamping as I'm finding it hard to learn how to spot the real thing. All three fender VIN's are good and the block is stamped also, haven't managed to get a good block photo as the stamping is very faint.
    [Blocked Image: http://i1233.photobucket.com/albums/ff388/6R07K/P7052297.jpg]
    Thanks in advance
    Ben.
    Cheers
    Ben
    66 GT Koupe, May San Jose build.
  • Well I'm certainly a long way from being an expert on VIN stampings, but that tranny product looks creepy to me. The stamping pad looks as if it was worked over by a grinder/file or whatever. The 'K' appears to have been the product of three individual wacks of whatever imprinted that first diget of the VIN. All in all I see nothing genuine about it.
    I suppose it could be that the transmission case had to be replaced, and that was someones misguided effort to link it back to the cars' VIN.
    But if all other VIN's seem in order, I don't think it's a show stopper to go ahead with the purchase. I do believe the current owner should be quizzed about it and perhaps it may serve as a purchase price bargining point.
  • I have no idea - however, if you like the car it sounds like you have a nice find there. I wouldn't let this detail detour you from moving along with a purchase.
  • I'd have to agree that that trans VIN is suspect rather intentional or unintentional, most trans VINs I've seen including mine are very faint but readable when cleaned up, and this one seems too defined and has the wrong type of font as well.
    I would recommend that you closely check the 3 VINs on the car-even if it means asking the owner to loosen and pull back the rh fender, and take a close look at the engine block VIN too. Have you done a VIN search on this site to see if its registered? that may be a start....
  • Thanks guy's
    Fender VIN's are 90% visable from the under side and its in the registry, original steel everwhere except the bonet.
    You have come up with the same points I had. The "K" set off alarm bell's, but from other photo's I've found the font seemed pretty good.
    The K on the block is fine and I would say the font is the same as the transmission?
    Cheers
    Ben
    Cheers
    Ben
  • I also have a 6R07K stamped transmission that looks similar to your stamping. The "7" and "K" seem to be struck using a single line die to form the digit by hand. The rest of the VIN looks normal. To venture a guess; could it be that at San Jose the "K" stamp tooling was worn-out , destroyed, or mis-placed and just formed with straight lines? Mine is a later production date than the yours. It would seem that subsequently the "7" stamp tool was not used on mine.
  • Interesting.....any others with patched together K's from SJ?
    Still interested in people's view of the font. I've found pictures of other VIN's some from this site that make me think all but the K look good?
    Cheers
    Ben
    Cheers
    Ben
    Edited once, last by 6R07K (July 28, 2011 at 8:52 PM).
  • The K appears to be a 1 used to form a K. Can't recall having seen other SJ cars that looked like that. Generally the block and trans were stamped at the same time they went down the line with the same alpha-numeric stamps. The K has definitely been dummied up.
  • On my Oct, 65 San Jose "K" Fastback, most of the engine's VIN is barely visible as in lightly stamped. It is in sort of a straight line and the most visible character in my VIN is the "1" (I have three in the number part of the VIN) but it is nothing more than a vertical line. I believe that they were hand stamped so the "1" (or "|") has the least amount of surface contact of any character and would be imprinted deeper in the block. Your "K" looks like that vertical line used to create a worn or missing (lost, misplaced or stolen) "K".
