Do I need to install a thin piece of rubber or something else between the spring perches and the leaf springs to prevent noise or any other issues?
rear axel assembly
Only if you are working on a Camaro!
Larry
There is a torque spec for the U bolt that is worth paying attention to. There is more stretch in those U bolts than you might think and it takes a bit to pull them down evenly. Not a bad idea to put on fresh lock nuts either.
Quote from 63Kcode
Only if you are working on a Camaro! Larry
Or a Cougar.
Quote from 66kcode
Quote from 63KcodeOnly if you are working on a Camaro! Larry
QuoteOr a Cougar.
Actually, in 1965, Mercury Comets used a rubber insulator that wrapped around the leaf springs where they attached to the perches on the rear axle to cushion and isolate.
On the early 65 Dearborn Mustang I have seen a thin paper like between the perch and the leaf spring.It looks like brown wrapping paper and is a tad bigger then perch.
