My Autolite battery died it is time to buy a new one . Does any one
have the sealed Autolite battery if so how do you like it. Or should i buy the old type that they ship to you dry.
Thank You
Mike
Thank You
Mike
I got 4 to 5 years out of my last two dry (add the acid and charge) type repop batteries. Just bought a maintanance free one last September, not sure what the life span for this one will be but I suspect the 4 to 5 year range is probably also a good estimate.
Jack
I have the maintenance free battery. I've heard too much about problems with the other battery spewing acid. If it were me I'd spring for the maintence free battery.
Hi
I will give the maintence free one a try.
Thank You
Mike
I second the maintenance free/sealed battery. My 64.5 K has gone thru
one and is on the second in 8+ years, the first lasted over 6 years
in the desert SW. I wouldn't have another "lead/acid" in any of my
5 Mustangs even tho the sealed battery is NOT CHEAP: the acid spew
makes for a MESS!!!!
I have bought my repro/sealed 24F batteries from Virginia Mustang and will continue to do so as long as I need them/as long as they are available/as long as I have my Mustang(s).
Hello, Mike, I purchased a MCA approved gel battery a few years ago for my K code and maintain it with the Battery Tender, no problems, it always is charged and starts when I want it to. Best of Luck.
Where did you buy the MCA approved gel battery and how much was it?![]()
G24F AutoLite®StaFul
Red Ford Caps
10 ¾” H x 6 ¾”W x 9”H TO TOP OF POST
http://www.restorationbattery.com
Phone: 513-574-4481
E-Mail: restorationbattery.cinci.rr.com
Maintenance Free $235
Maintenance Free: No Acid - No Leaking - No Boiling Over. Made with the Same Cases, Top Covers, and Removable Caps as our Lead Acid Batteries.
Delivered FULLY CHARGED and Ready to Install! 4 yr warranty.
I got the maintenance free battery. It was $260 with shipping.
I have a battery tender and have used it for years now. I found a lot of vendors do not stock the battery. When you order one, they have it drop shipped to you. I bought mine from Shelby Parts and Restorations.
Thank You For the all the feedback.
Mike ![]()
Is this battery the same as the one that Antique Automobile Battery sells?? We bought one for our '57 Chevy (seald) and I wasn't under the impression that it was gel???
