Unique K Code Parts
  • How about a fresh look at a comprehensive list of the unique K code parts and part numbers? (There are some items missing in the 4th edition HiPo book.) Here is a partial list started by jcw66k in another thread and I have added to it. Please do not include the GT and/or dual exhaust parts that would have been used with other models. Stick to K code only parts.
    Crankshaft
    Connecting Rods
    Crankshaft "Hatchet" Weight and Roll Pin
    Timing Chain Set
    Camshaft
    Lifters
    Valve Springs
    Vibration Dampener Bolt & Washer
    Valve Covers
    Air Cleaner & Filter
    Choke Cable & Bracket
    Flywheel
    Clutch Disc
    Pressure Plate
    Clutch Equalizer
    Clutch Equalizer Pivot Ball Bolt (block)
    Exhaust Manifolds
    H Pipe
    Arvinode Exhuast System
    Transverse Dual Exhaust System
    Water Pump
    HiPo Fender Badge (added 1/9/2010)
    High Performance Equipment Manual (added 1/9/2010)
    Deleted HCC AX steering box from list as it was a GT package item.
    Edited once, last by Round2k (January 9, 2010 at 3:56 PM).
  • Dave, The Hipo steering box is the same number as a GT without power steering as they are both HCC-AX.
  • I agree with you on that Charles. I was just trying to address it as being part of the GT package as that is more widely recognized.
  • The most obvious (the first thing you look for on a Mustang), most desired (which implies the performance), simplest (it's a small die cast item) and least understood by novices (all the performance parts that support the car's mystique), the "High Performance" plate behind the "289" on the fender, C4ZB-16C236 or C5ZZ-16228-B.
