1/4 mile tips
  • hi
    I'm going to Alastaro to test my K-code performance and i need some tips how to get fast start with manual transmission without breaking anything?
  • Quote from seisei
    hi
    let the clutch take the abuse. It's the cheapest part of the drivetrain. You can burn out several clutches for the price of one transmission.
    find the lowest rpm that will let you launch without bogging, and let the clutch out as fast as possible without wheel spin.
    It just takes practice, and some experimentation.
  • I'm going to next weekend to ford nationals days in Alastaro.Let's see if mustang goes under 15 seconds.I try to get soft start with clutch.
    is 5000rpm good time to change next gear?
    can someone tell me how to make stop the hurst shifters rattle?
  • most rattles can be reduced by adding a shims or washers to the shifter arms at the rods.
    I would shift at the maximum HP rpm. Probably closer to 6000.
    Edited once, last by zrayrichter (July 8, 2009 at 6:26 PM).
  • the best start:
    60ft=2,530
    330ft=6,695
    660ft=10,214
    990ft=13,267
    1/4mile=15,867
    I change gear on 4500rpm, feels like car is moving better in 3000 - 4000rpm.
    Edited 3 times, last by seisei_old (July 14, 2009 at 9:46 AM).
  • I have taken 2 trips to the drag strip. The last time was 3 years ago.
    I really enjoyed it and would like to do it again. Problem finding the time though :(
    Traction was a problem as well as my reaction times.
    The 14.3 @ 100mph was with 3.25 gears. I now have 3.80 gears.
  • Here is link to my 1/4 mile
    External Content www.youtube.com
    Edited once, last by seisei_old (July 19, 2009 at 2:56 PM).
  • oops, the text... oh yes...
    I think the gears would be 3.89, also called 3.90's. and if you shift @ 6,000 RPM or slightly higher, you should see times drop and speed increase. Try it and see what you get, and then report back to us with the results, we ARE interested.
    :D:D
  • Get some 7"-8" slicks and quite letting the new 5.0's put it on you.The old 289 at 7800rpm is where you should be.My ole 65 Super Stocker Mustang I use to bring out at 10,000rpm and shift it about 10,200rpm and man did it leave!...All shifters ring as that's why they are spring loaded.
  • My car total advance was 48 degrees BTDC ! .Now it is 36 degrees and feels like that i get more horsepower.I don't know what is the best advance..Next i change points and let's see what happen..
