I recently removed my plugs before a valve adjustment, but could not remove the plug from cylinder #3 because there was not enough clearance between the exhaust manifold and plug. I'm not sure even the thinnest wall plug wrench would fit. I'm thinking about loosening all of the exhaust mainifold bolts and hoping I could slide it rearward about 1/16" to clear the opening, but don't want to go through that if there is an easier way. Anyone else ever expereince this?
Walter
