FOUND - Block for 6T07K203710
  • From FB Group "HiPo K code Mustangs - Appreciation Group"
    Owner is Michael Bruns from Germany. He posted pics below with comment on Jun 4, 2021. He would let it go to the owner of the original Kar, but otherwise not for sale.
    Michael Bruns
    If the owner of 6T07K203710 is out there - I have your Block 😉
    Link to his FB page: https://www.facebook.com/bruns.family
    Info from his FB page:
    Studied Mechanical engineering at South Dakota State University
    Went to Alexander von Humboldt, Lima Peru
    Went to Colegio Alexander von Humboldt
    Lives in Karlsruhe, Germany
    From Bogotá, Colombia
  • That block is only the second VIN stamped Metucheon block that I have heard of. I had a 66 Hipo GT pony interior T5 convertible, which are Metucheon Kars, and it did not have a VIN stamp on either the engine or transmission. I was almost of the belief that Metucheon Kars did not get VIN stamps on the engines until I actually acquired a block which I still have.
  • Fred-
    My ‘67 k code is a Metuchen built fastback. It was imported to Belgium from new. My block isn’t stamped in the usual place, it’s stamped on the pad just in front of the driver side cylinder head. The gearbox is vin stamped.
    John.
  • Fred-
    John.
    The stamping in the area you are referring to is normally the build date of the engine assembly. It would read something like 7B22A. Is this what you have as that area is not big enough for a VIN stamp?
  • I can still make out the build date code on the tab but the full vin has been stamped over the top, it’s tight for room and a little uneven but it fits. I’m thinking it was done when imported into Belgium, maybe a requirement?
    John.
    John.
    That is an interesting anomaly which is why Evan is asking for a picture. There is always something to learn on these Kars.
  • I’m thinking this was done when imported into Belgium from new or when it was imported into the UK in ‘72
    Thank you for posting this picture. This is quite unique for VIN stamps. I would think that whatever country required this, that all engines for all cars would get the same treatment.
  • Fred-
    Something else you may be interested to see.
    Obviously something done when imported into Belgium.
    John. The content cannot be displayed because you do not have authorisation to view this content.
    This is great documentation.
    Mexico requires a similar Federales sticker to be placed on the right hand door striker pillar on imports. I restored a 1965 Mustang fastback for a customer in Mexico City many years ago and I learned this from the owner. Ford built Mustangs in Mexico, but NOT fastbacks so it became a very limited import.
  • Evan-
    Yes that is correct, 7T02K203974 and the gearbox is vin stamped
    however the K is missing on the gearbox vin, have you come
    across that before?
    Your welcome to put it in the data base. I also have the buck tag
    and build sheet for this Kar you may be interested to see.
    John
  • I have actually had a K code block where the K was stamped reversed in the VIN. Sounds like an assembly line shenanigan to me! Yours is most likely just an error by the worker at the time.
  • Metucheon block? is it common for these assembly plant blocks to lack the stamped VIN?
    There is some evidence and speculation Metuchen wasn’t as good at putting vin stamps on blocks but I have seen several photos of Metuchen hipo vin stamps, just not nearly as much as San Jose and Dearborn.
    Evan
    6T09KXXXX80
