• I bought a HiPO camshaft off Ebay, advertise as NOS Ford C3OZ-6250-C in the original Ford tube.
    The cam is definitly new, but I'm not sure if it's Ford. It does not have "VE" (V is an upside down A) next to the last bearing journal.
    It does have "K 104" on it, with 2-pink paint dots on the end, a pink paint daub at one end, and an orange paint daub at the other end.
    Is this a Ford NOS unit, or did I get taken?
    Thanks in advance.
    Edited by - jansawj on 12/24/2007 20:53:54
    It could be a later service part; some of them do not have the upside down AE. Does it have a Ford logo anywhere?
    <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana" size=2 id=quote>No, no Ford Logo, no Ford casting/part number ... just K 104
    If you have a micrometer or caliper you can measure the cam lobe lift 289Hipo cam both intake/exhaust 0.298"(.298" x 1.6 rocker arm ratio = 0.477" theoretical valve lift)
    [Blocked Image: http://www.tpub.com/content/constructionloader/TM-5-3805-258-24-1/img/TM-5-3805-258-24-1_402_2.jpg]
    A.Lobe lift,= B.Lobe height,- C.Base circle.
    Edited by - kar-nut on 12/26/2007 16:39:05
    B - C = Lobe Lift = 1.720 - 1.421 = 0.299 looks good
    Thanks to all for your help.
  • I have had several NOS Ford Hipo cams that were later production pieces with the same markings as yours. Your lobe profile looks correct as well. I may still have one like that as an NOS Ford part but it is fairly inaccesible at the moment.
  • It would be valuable information if there is there a ford service publication or parts dept TSB out there that would identify a later service replacement K code camshaft by markings and castings on the cam itself , i have looked in the fourth edition registry and Bob Mannels book and found no reference to it.
