New e-Bay Listing: 65 K FB
By Seller: "radical4d"
In: Auburn, IN
Starting Bid of $18.5k
Listing Info:
QuoteDisplay MoreData VIN/Dataplate info:
63A -Body: Fastback, Standard Interior, Bucket Seats
5 - Color: Twilight Turquoise / Car is now painted white
D6 - Interior (Trim): White w/black / Interior is now two-toned blue/white Pony
16Q - Date: 16 March, 1965 (2nd year)
35 - DSO: Lansing
5 - Axle: 3.50:1
5 - Trans: 4-Speed Manual
Vin (Warranty Number) Breakdown
5 = 1965
F = Dearborn, MI
09 = Fastback
K = 289-4V HiPo
664967 = Consecutive unit number
THIS 1965 HI-PO 271 HP "K" CODE MUSTANG UNIQUE FEATURES:
The HiPo came with ordinary cast iron 4V intake, an Autolite carb, stamped steel valve covers, and standard 289 oil pan without a windage tray. Spring cups in the heads, the screw-in studes, open-element air filter, and swept exhaust manifolds
The HiPo block is an ordinary 289 block, only the caps make it a HiPo. The caps were beefier then the standard caps.
Thick harmonic balancer
Front bobweight - the HiPo used a timing chain with a unique thin lower sprocket to provide room for the bobweight.
HiPo heads have screw-in studs. Ford used 'close-tolerance slots" in the head castings to guide the pushrods. HiPo heads only unique feature - the "cup" that holds the valve spring
Distributor: C50F12131B
Intake Manifold: C50E9425C
Carb - Holley 804S7-2 0432
Fender #'s: 410C3
Right Side Head Identification: 5B16
Left Side Head Identification: 5A11
Special Handling Package consisting of quicker 16:1 ratio steering box: Tag #'s: HCCAX top, 5C17C bottom
Larger diameter sway bar (13/16")
Heavier front and rear springs (9" rear)
Heavy duty shocks
Front 4-piston disc brakes with larger master cylinder
Dual exhaust through rear valance
Reinforcement exhaust hanger plates inside the car behind the rear seat
Factory bolt plate inside the rear frame rail
Rear brake hose located further outboard to clear pipes
Rear bumper guards deleted, and mounting holes in trunk plugged
High Performance badges
5 dial instrument cluster with dash structure stamped with round "moon" to clear round speedmeter
Flat 1965-specific glove box door
Pony interior
Fog lamps and unique grill trim, fog lamp switch located on the face of the dash panel under wiper switch
This Mustang is a good driver as it is... It does need some sheet metal work done to the undercarriage floor board driver side. Frame rails, engine compartment and trunk are in good condition. Motor is in good condition and engine runs extremely strong. Engine has been tuned with new plugs, oil change, filter, etc. All lights and instruments work on the car. The shifter on the car needs attention, however the car shifts through the gears nicely. The carpet needs to be replaced. The headliner has two small holes under each visor. The driver seat needs to be re-stitched. The car interior is very clean. The paint has several bubbles coming through around and near the rear vents. Car needs to be restored. There is a small area on the passenger door where a minor amount of glass was used, other then that the car is smooth and not wavy. Engine and engine compartment is great for the mileage and original to the car. Metal is in good condition, windows and glass in good condition, vents work fine, rear seat folds down perfectly and the trunk passageway to interior is in tack and working fine.
Car includes new Cragar SS Wheels and B. F. Goodrick TA Radial Tires with transferrable warranty. Also includes original steel styled wheels and older tires.
Please call us to arrange to see the car. We advise that you see the car before bidding! We are available days and evenings during the duration of the auction. There is no warranty or guarantee expressed or implied when you purchase this vehicle. If you are the winning bidder, there will be no arguments when you come to pick up the car. The deposit is non-refundable. We reserve the right to remove the car from the auction. Please call with any questions or to see the car - Rick or Melanie 260-927-1158 or cell 260-438-1049.
