Ok this car has been discussed a couple times here,
http://www.hipomustang.com/hpmx/topic.asp…rms=6T08K280257
and is being relisted here
QuoteDisplay More1966 Factory ordered Mustang K CODE GT Convertible with pony interior! Wimbledon White with black pony interior. Numbers Matching 52,000 mile car which is documented on the title. This is a real show car and is a documented multiple best-of-show winner, this car comes with 7 historical competition trophies, original 1966 owner's manual and Hi-Po equipment specifications guide. This is an immaculate and nearly flawless example of a high-performance ragtop GT Mustang that can be driven, shown and enjoyed for many years!
This Hi-Po underwent rotisserie restoration in 1985 and has been driven about 2000 miles since then. The car was rebuilt with NOS parts during restoration and starts and runs like new; there are no leaks, no smoking, no oil burning and all engine parts (carb, distributor and complete drive train) are correct and original, including dual-points ignition and all platinum spark plugs, rotor, cap & wires. This 4-Barrel 289 CID comes equipped with the original 4-speed, 3.50 axle, rally pac, 8K tach & clock, styled GT steel wheels, front disk brakes, chrome locking nuts with Bias Ply tires. All the lights and instruments are in working order and yes, the taillights do turn on with the fog lights. Convertible top is like brand-new, tight and clean and comes with a boot as well. For those Hi-Po and GT guru's out there - you will be pleased
In short - It’s kept in humidity controlled room and Everything is in excellent shape – please look at the pictures -
CODES:
VIN # 6T08K280257
BODY COLOR TRIM DATE D.S.O. AXLE TRANS
76B M 66 13G 13 5 5
For those serious buyers - I have aprox 80 -100 pictures of the car - once you start the bidding - if you like i can send more pictures
As you can see from previous threads, this "immaculate and nearly flawless example" which "underwent rotisserie restoration in 85" has had the back end replaced. Check out this pic worth a thousand words :
