Reserve not Met @ $24,699.00 E-Bay Listing: 67 K FB
By Seller: "10theng"
Quote1967 FORD MUSTANG GT, only 472 of GT's were ordered with the rare K-Code V-8 engine. (GT was a required option for the K-Code engine). The GT Equipment Group consisted of the grilled-mounted foglamps, power front disc brakes, dual exhausts with chrome quad outlets, GT gas cap, the handling package, rocker panel stripes, and GT emblems.
This is not a show car. The car was restored in 2000. It came with standard interior, but was converted to deluxe interior. All numbers match! 289 Hypo, 9" rear, 4 speed, 350 open case rear end, dual factory exhaust, paint code Y which is moss green (but car is painted red). Car has both consoules, 6 grand tach and clock. You can tell by the pictures the car is VERY CLEAN and has been well taken care of. THIS is a true GT. The car has won first place in a local car show (but I think there were more trophies than cars). This is a forty year old car so it is not perfect. If you have any questions please e-mail me.
Question to seller:
Q: Hi, I am interested and you may have heard this already but that Vin stamp on the fender apron does not look stock. Usually they are hidden under the fender, not deep like that, not crooked and have a star stamp. Thanks
Nov-27-06
A: thank tou for your interest in the car , your right the vin numbber is not stock.Ive had this car for 11 years, I bought it form a estate sale.the car had no fender aprons and no vin number under the hood. in fact it had no hood or fennder or core suport.the only thing I have to prove this is a K code is the origanl door tag and the title with the vin number on it.I also have a 289 with aharmonic balancer that is 1-13/16 inches thick, a dual point distributor ,cast iron free flow exhaut mainfolds.crankshaft counter weight,3/8inch rod bolts. the heads havscrew in rocker arm studs and narrow push rod slots that serve aspush rod guide plates.so IAM pretty sure this is a hy po 289.this car is 40 years old its nowhere near 100% origanl thank you.
Q: Can you provide me with the door tag information? I cannot read the codes from the picture you provided. Thanks in advance, David
Nov-26-06
A: thanks for your question.the door tag on the car is a re pop.i have the original tag and it reads 63a y 2a 01c 34 5 5 vin number is 7f02k169034 thanks
Q: K-codes came with 8K tachs not 6k. it was the only 1 in 67 with 8K tachs. all others had 6k tachs. so what happend to the 8K tach for the car??
Nov-26-06
A: this came with a 6k tach the only other k code ive ever seen on ebay also had a 6k tach maybe you can check with the k code registry and they can shed some ligth on this tach question.
