• I just spent 3 hours in my very hot garage trying to install my full length console in my convertible. I removed the choke cable bracket and all the seats. I was able to test fit it in there without the support braket. Once I installed the metal support braket (area under the glove box), I cannot get the console in there. I can't see how it will fit under the dash and get over this bracket. The bracket will not install if the console is in place first, so what can I do? Also, the shift lever (4 speed) in the way also is a bit of a problem, but not as much as the clearance under the dash.
    I have mass backed carpet w/jute over the factory style sound deadening mat. It was killer trying to get the bracket to even mount through all this, but I eventually got it done and tightened down.
    Edited once, last by 66gtk (July 28, 2011 at 3:42 PM).
  • I suppose I could try cutting out the carpet around the bracket base, but the under carpet padding is already cut in this area and if I cut the carpet, there is no turning back. not sure it will give me much more clearance - maybe an 1/8"??? I will try it. Do I at least have it positioned the right way? If it's flush to the floor, will I have trouble getting my console to seat close enough to the floor with the thick carpet and such?
    AAGGGHHH!!!
    Edited 2 times, last by 66gtk (July 27, 2011 at 4:05 PM).
  • Ran into the same issue on the F/B about 6 yrs back. My fix was to make another bracket, but I shortened the height a little something north of 1/8" and concaved the lower flange to better comply to the tunnels' shape. Still a bear to get the console in (and out I might add), but doable.
  • I have to let things simmer before attacking again. A clear head does wonders (:
    In the meantime, here's how I found my floors. Did the factory use all this sealer, or a PO? It's a Dearborn car. Also note the high beam, power top and fog light wiring....any comments? Looks like a repair splice and a bunch of old original wiring.
  • I know that this has nothing to do with your console fit issue but why is the choke cable on the right hand side of the steering column?
  • I just put the console back into my 66 fastback the bracket was long gone, i purchased a new Scott Drake bracket mounted it to the bare floor, slit theunderpad and carpet, no problems with te install.
  • Troy, I had three Hipo GT convertibles with power tops and the choke cable mounted to the far left under the dash pretty much below the fog light and top switches.
  • Yep, I removed it when I put the carpet in, and now I'm going back to the console. I got all new reproduction metal top pieces and repainted it to look like new again. I like to keep things changing every once in a while (:
