headers for 66 k code mustang
  • please would some one recommend the BEST FITTING header for 66 k code 4 speed mustang, I have been told jba 1650sjs work great & others say they were a PAIN. I do not want to cut, bend or pound. Thank you for any advice.P.S. would like arvinode from h pipe back.
  • I went thru 2 sets of Patriot Tri-y headers before I found a set that fit w/o "adjusting" . I got the nickel plated ones. Patriot headers are the least expensive, but mine have lasted about 8 years so far.
    Long tube headers are likely to reduce your low end power, so I would steer clear of them unless that is not a concern for you.
    I think J. Cowles at shelbyparts.com has the best tri-y headers but they are $995.00 a set.
    Z.
    Edited once, last by zrayrichter (November 28, 2010 at 1:38 PM).
  • Quote from 289kford
    I heard a while back that the tri-y's made by Scott Drake will fit, and fit like they should.
    I wasn't aware that Scott Drake made headers.
    Edited once, last by 289kford (November 29, 2010 at 8:30 AM).
  • I put Doug's Ceramic Coated Tri Y's on my 65 K. Only a slight adjustment of the Z bar was needed. Great fit, and they still look like new aftermore than 7 years on the car. Worth a look.
