Which spark plugs do I run? 67 289K
  • Ok guys, what plugs would you run? I'm ready to start my 67 289 K engine in my GT 350. The engine is all stock built, .30" over. I have Autolite BF32 plugs and Motorcraft BF42C plugs. Thanks Randy
    Edited once, last by SixT5HiPo (May 30, 2008 at 10:07 PM).
  • I have been running BF32's for over 30 years
    in my 67. Worked fine at all times. Gapped them
    at the recommended 0.028-0.032" until I installed
    Pertronix, coil and ignition wires at which time
    I increased the gap to 0.032-0.035"
  • I have been using BF42's which are the equivalent of the BF42C Motorcraft that you have. They never foul and produce good plug readings for all of my driving. They are also expendable whereas your BF32 plugs can sometimes foul with around town driving and cost much more to replace.
  • Ok, I have an old autolite spark plug guide book, it says .035 for BF32, should I go .032?
    Maybe better to run in on the BF 42's until I get a few miles on the engine?
    Randy
  • Well I ended up running the BF32 plugs and she runs real crisp and strong. Engine is just broke in so far, so will keep an eye on them to see show they fair. Randy
  • Sold auto parts in high school and college - saw this happen a total of 2 times in about 7 years - I wouldn't worry. The plugs won't degrade and are crimped together - only if the crimp is bad would this happen.
    I ran Autolite 45's in my HiPo for a number of years after the other plugs got hard to find - never fouled one either.
    I've always tried to gap on the low side of the recommendation. The gap will increase as the plug ages and the tip erodes, so you stay in the correct gap range longer - just don't over do it.
