Is it possible for coolant to leak out at the top of the timing chain cover (I'm not a mechanic)? The area right near/to the left of the thermostat housing. I originally thought my bypass hose clamp was leaking, causing a coolant puddle on the timing chain cover, but I've had the hose off and had everything cleaned up for a month and haven't driven or started the car since. Found a nice puddle there when I was prepping to paint. The gasket near that area feels very soft. Any suggestions?
I cleaned and painted the entire area and will keep my eye on it. Perhaps the paint will help seal - anything else I can do to seal or should I just go ahead and have a mechanice pull everything off and look around since I have it all accessible at this point. I do know that the timing chain was replaced about 10K miles ago, but that was also 13 years ago as well.
