Water pump question?
  • OK, before I got really into restoring my motor I think I got rid of my water pump:( I am going to look around, but pretty sure it's gone. Are they really hard to find as a reconstructed one? Currently I have a 289 in my car that is NOT my original motor, but would like to compile the correct parts for my numbers matching motor.
    Thanks
  • What is the date of your car?
    The correct waterpump for your car is determined by the change level of your engine and the model year somewhat.
  • Steve, I have sent you both an email and a PM on this.
  • I have an aluminum water pump that was kept as a backup from my 66 "K". The car was produced in December of 65. Part number is "C40E-8505-A" with a "5" underneath. It has a circle of dots with "63" stamped in the center (production year I assume). It also has an 8 vein impeller.
    A buddy had an extra one for sale...so I changed it out and had it rebuilt...
    I was not the original owner...however, because of the low mileage at the time, I believe it was the original pump...can anyone give any background history/opinion.
  • David, Your pump is actually not correct for your 66 as it is for a generator car. The 8 vane impeller makes it for a standard rather than a Hipo engine. Your 66 should have a cast iron water pump with a C6OE casting and the appropriate timing cover.
  • Iowa Dave, I just sent you a PM regarding your pump.
